Question about Genie Company Genie Intellicode 1-Button Transmitter With Visor Clip, 35656T
Universal receiver for garage door opener ACSR3
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
I need the receiver and garage door control button for a NuTone Garage Door Opener Model GB575, GB580 & GB580-8
I think you will need to check into a Sears Model #00953751000 or Chamberlain Model #R39663 universal remote control replacement kit.
Apr 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
Can a universal remote be used with Sears Model 139.664300?
Not just a universal remote but a universal remote control replacement kit can be used. It consists of a remote and receiver. It is available from Sears and the number is:
Model #00953751000
Jan 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
This doesn't work for me. I've tried everything. I'm getting very frustrated, and am trying anything to prevent me from purchasing a new garage door opener. I just bought the condo, and received no garage...
It seems you have done everything right. I would return the universal remotes to Lowes and purchase the correct remote for the opener. There have been several people with universal remotes and this same problem.
Nov 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie Garage door will not close. Receiver Model: ACSR3 FCC ID: BBQ ACSR3
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Aug 20, 2010 | Genie Company Genie Intellicode 1-Button...
Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
Genie Company Genie Intellicode 1-Button Transmitter With Visor Clip, 35656T Logo
461 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
