Question about Ricoh Office Equipment & Supplies
I get the error sc352 on a Ricoh Africio Ap4510 printer. it is a mono A4/A3 printer. i looked up the code and it is: ID Sensor/Pattern edge detect error 3 magenta TD sensor initial setting error. anyone know what the problem is? and how to fix it? The error comes up when i am trying to print an A3 page. I get a page jam first and usually a second or third time as well as it try's to print the page after each time I clear the jam. The error code then comes up.
Inky
  • 691 Answers
SOURCE: Jam A - strange sound
Hi Aleks, This is a known issue on certain AcuLaser C4100 for which Epson have released a countermeasure. The problem is related to a value in the printer firmware and only realy affects the machine when it is first switched on or has sat idle for a long time whilst powered on. The fix requires a software tool to interogate the firmware and check a value. If this value is set to a certain figure it requires changing. The same software can change the value to rectify the issue. You can get the info to fix the printer from: http://www.tradebit.com/filedetail.php/1594428
Posted on Mar 15, 2007
  • 58 Answers
SOURCE: aficio color 6513 id sensor location, td sensor location
toner density sensor is located in the developer unit. either the sensor is not reading cause something is covering it or it has poped so it can not reference any longer.
Posted on Oct 17, 2007
jaylex
  • 417 Answers
SOURCE: A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Posted on Feb 17, 2008
  • 3 Answers
SOURCE: Magenta colour comes through on all prints
We have over 50 of these printers and a few have had the magenta bleeding problem. On everyone of them the problem was corrected by going to the clean developer function under Maintenence from the Menu and choosing to clean the magenta color. Usually have to run it a couple times but it has always corrected the problem so far.
Posted on Jun 11, 2008
SOURCE: Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Posted on Oct 17, 2008
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
What is the Ricoh error code sc406?
Code
SC406
Description
ID Sensor Error 4: ID Sensor Pattern Not Detected
At the ID sensor pattern check of the covered area of the ID sensor pattern, the value of the edge voltage was not 2.5 V for 1.5 seconds.
Causes
• ID sensor harness, connector is loose, broken, or defective
• ID sensor dirty
• ID sensor defective
• IOB defective
• LD Unit defective
• BCU defective
• Development power pack defective
May 02, 2014 | Ricoh Office Equipment & Supplies
Error code SC 352
SC352
Error Code Explanation :
ID sensor, pattern edge detect error
The ID sensor pattern edge voltage is
detected to be not 2.5V twice
consecutively during an 800 ms
interval.
Posible Causes :
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• Dirty ID sensor
• Defect at the ID sensor pattern
writing area of the drum
Sep 15, 2013 | Ricoh Aficio 1035 Copier
What is a 350 code on a savin 8045 copier
This code can be reset be turning off the main power (orange rocker switch) for about 10-seconds and then turning the machine back on. If the error comes back up, then there is a definite problem with the machine and it should be looked at by a train service technician.
SC350:
ID sensor pattern test error
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Causes:
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
Apr 01, 2011 | Office Equipment & Supplies
When i print a file from my computer it stops at a definte number of pages then it gives me sc352 so i have to shut down the machine
SC 352 problems can be.
• Dirty ID sensor
• Defect at the ID sensor pattern writing area of the drum
I guess on one of the two latest
Oct 14, 2010 | Ricoh Aficio 1035 Copier
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Error SC 350 on Aficio AP4510
ID sensor defective
connection
defective
• ID sensor dirty
The problem is with your id sensor , it is sitting on the back side of the drum , in other words the further side of the drum when you slide it back in to the machine , these sensors get full of toner and gives this code , or the drum surface gets damaged and do not send the right patch to the system .you can whipe this sensor with a cloth .
Aug 10, 2008 | Office Equipment & Supplies
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Ricoh 420 SC270 error
i want to solve this problem of sc 122 code in my photocopy want can i do to remove this code. because i can copy the A3 papers even to resize A3 to A4
Jul 17, 2008 | Ricoh Office Equipment & Supplies
152 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
