Question about KitchenAid KSRS25RVMS Stainless Steel Compact Wine Cooler Side by Side Bottom Freezer French Door
Kitchenaid ksrs Icemaker not working, no water in icemaker
Water dispenser works, but no ice
  • 35 Answers
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Replace the ERC board.
Posted on Dec 09, 2007
SOURCE: No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Posted on Jul 01, 2008
  • 330 Answers
SOURCE: In door water/ice dispenser not working
check the connect part, see if the gears in the right position.
Posted on Jul 02, 2008
  • 85 Answers
SOURCE: kitchenaid ref's icemaker water line shutoff
http://home.howstuffworks.com/icemaker.htm
click the link.
Posted on Feb 26, 2009
SOURCE: Kitchenaid Superba Icemaker not working
You can sign up for my advice for $8.99.....
Posted on May 16, 2009
Kitchenaid refridgerator/freezer/icemaker model KBFS5ET5500 EVERYTHING WORKS BUT THE ICE MAKER...JUST QUIT. THERE DOES NOT SEEM TO BE A SHUTOFF VALVE AT THE BACK OF THE FRIDGE. I AM LOOKING TO SEE IF THE...
Hello Raymond,
In a most of cases if the filter were clogged it would affect BOTH the icemaker and the in door water dispenser,its never a bad idea to replace espically if they is a foul odor or taste in the ice or water. The water valve on the back is going to the most likely problem if the in door dispenser works yet the icemaker does not,a lot of times when the water valve is bad when its supposed to be fully closed cutting all water flow into icemaker it stays open a wee bit allowing water to seep through it causing the hose that connects to it ,running up the back wall into the icemaker to freeze up at the top where the tube enters into the freezer,that tube needs to be thawed, and to prevent it from freezing in the future the water valve needs to be replaced.
Goodluck,i hope this helps you to fix your icemaker,
Gene
Aug 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
ICEMAKER HAS NO WATER IN IT AND ICE STRIPPER NOT MOVING BUT WATER DISPENSER WORKS KITCHENAID SUPERBA MODEL #KSCS23INBL00 SIDE BY SIDE WITH ICE AND WATER DISPENSER IN DOOR
First check to make sure the icemaker is on. Most icemakers have what looks like a wire that extends to the right. Down is on, up is off. If yours does not have this, there might be an on off switch on the icemaker itself. If the wire (bale) is on, or the switch is on, then the icemaker is defective, unless the freezer is too warm. Icemakers have a thermostat in them that will not let them operate if the freezer is too warm. Sometimes that thermostat will not activate until the freezer is 15 degrees.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Jun 17, 2008 | KitchenAid KSRS25IL Side by Side...
Oct 18, 2007 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid KSRS25RVMS Stainless Steel Compact Wine Cooler Side by Side Bottom Freezer French Door Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
