Question about Air Conditioning and Heat for Nissan Pulsar
Cigarette lighter fuse location
2001 hatchback. what to check for if cigarette lighter does not work.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
12V accessory fuse. if thats good remove the jack and unplug the wires and check for voltage at the wiring harness with a multimeter. if thats good 12-14.5v then check for continuity between the dot in the center of the lighter jack and the middle peg on the back, and the sleeve of the lighter jack and the peg on the side of the jack. make sure the connection is tight between the harness and the jack and reinstall. if it still doesnt work then replace the jack
Posted on Apr 24, 2014
Cigrate lighter,radio and foof light does not get on even fuses ar good for toyota corolla 2001
Check these two fuses. Fuse number 31 in fuse box location 4, if cigarette lighter, radio and clock. Else fuse number 5 in fuse box location 2, if only radio and clock and not cigarette lighter.
Feb 06, 2015 | 2001 Toyota Corolla
2001 cigarette lighter fuse location
The cigarette lighter fuse is the fuse that is marked "CIG" in the fuse block in the left end of the instrument panel. (Also see picture)
Jan 14, 2012 | 2001 Toyota Prius
Cigarette lighter fuse in 2001 funfire
The cigarette lighter fuse is located in the instrument panel fuse block located under the left end of the instrument panel. It is a 20 Amp fuse and is marked "CIG". (See Illustration)
Nov 04, 2011 | 2001 Pontiac Sunfire
I have a 2001 toyota corolla, I recently plugged a device into the cigarette lighter, when i did the cd player and front clock quit working. I checked all the fuses and they were fine. what do i need to...
Your radio does run off of the same fuse that powers the cigarette lighter and auxilliary power outlet. I would check the fuse again. It is a 15 Amp fuse located in the Driver's Side Junction Block which is behind the left kick panel. The fuse should be marked "Cig"
Jan 08, 2011 | Toyota Corolla Cars & Trucks
Toyota corolla 2000 cigarette lighter no working
Check your fuse boxes - your drivers manual should show you where the fuse is located - there are several fuses that work with the cigarette lighter, one located inside the vehicle, left of the steering wheel, the other 2 located under the hood.
No need to pay a mechanic to do this, your owner's manual lists fuse replacements under "do it yourself maintenance" - My Toyota dealership quoted me $70+ to do this, when it cost me $5 to buy 5 fuses, now I have 4 spare.
Hope this helps.
Nov 03, 2010 | 2001 Toyota Corolla
Cigerette lighter
Most likely the fuse is blow. Either a 15 or 20 amp fuse.
Open the glove box and turn the 2 white tabs 90 degrees. then pull the fuse panel down. There is a white card stuck in the bottom of the fuse box that shows what fuse number is the one for the cigarette lighter. Locate this fuse, they are numbered on the fuse box. Then replace it.
May 05, 2009 | 2001 BMW 5 Series
No power to cigarette lighter, and no fuses designated as such for it 2001 chrysler sebring Sedan LX,
Did you check the fuses under the hood? The cigarette lighter fuse is not located in the fuse box by the passenger door.
Mar 27, 2009 | 2001 Chrysler Sebring
Which fuse is the cigarette lighter on a pontiac grand am 2001
The fuse is located in the fuse box under the hood, (on the driver's side)
Dec 02, 2008 | 2001 Pontiac Grand Am SE
Cigarette lighter not working, no power to it, can you tell me where the fuse is located for it
The fuse for the cigarette lighter is located in the fuse box on the driver side of the car under the dash. It is a blue 15 amp fuse.
When you open this fuse box, you will see some larger relays with 4 rows of fuses below it. The fuse you are looking for is the first fuse in the 2nd row. in the 2002 X-type, that fuse is a little taller than the other ones.
Thanks for using the fixya forums!
Jul 07, 2008 | 2002 Jaguar X-Type
Air Conditioning and Heat for Nissan Pulsar Logo
200 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
