Question about Microsoft Outlook 2010
How do i authenticate my smtp - Microsoft Outlook 2010
    Problem Solver:
  • 19 Answers
Goto your mail account on main website and click on setting there you see a POP3 setting, now enable it. so u can use your acc. in phones and outlook!! best of luck!!
Posted on Feb 23, 2012
How do i Fix Thunderbird Email Error 5.7.1 & 5.7.0 ?
the SMTP server couldn't authenticate you as a authentic user. Most email providers don't care who uses thier SMTP server to send a message to somebody in the same domain, so it may look like everything is working until you try to send a message to somebody in another domain.
In the Outgoing Server settings, Simply put, complete email id
Some common authentication methods:
§"SMTP-AUTH" has the user provide a separate username and password for the SMTP server. This is usually the same username/password used for the POP/IMAP server. Most email providers use this method. If your email provider uses this method goto Tools -> Account Settings -> Outgoing Server (SMTP), select the appropriate SMTP server, press the Edit button, and enter the username. Old versions of Thunderbird may also have a checkbox for "User name and password". If you have that checkbox, you need to check it. See the SMTP authentication article for more information.
§If you're using your ISP as a email provider it may check that you're logged into the internet using them. So this error might occur if you take your laptop somewhere else and use a public network. Setup another account with a free email provider such as Gmail and use that account's SMTP server with your existing account when traveling. See Multiple SMTP servers for more information.
§"POP before SMTP" relies upon the user checking for new mail (thus logging in to the POP server) and then sending a message within X minutes. See the POP before SMTP support article for more information.
§You need to use a Virtual Private Network (VPN) to connect to the SMTP server. This requires you to configure Thunderbird to use the appropiate VPN client.
If you're unsure what method is used go to your email providers web site and browse their email client support pages.
i hope it will resolve your problem don't forget to give the rating.
Dec 29, 2017 | Computers & Internet
Conection doctor is all red lights blocking me from gmai require help to turn them all to green can you assist??
Hope this helps: That is an indicator field which displays the account associated with the particular SMTP server within the list. This can be changed from selecting the SMTP Server from: Mail >>Preferences >>Accounts >>Account Information, then select from the pull-down menu for "Outgoing Mail Server(SMTP):" Make sure you save it.
As for the sending issue I would need more info. Similar to your Incoming Mail Server, does your SMTP server require authentication? Connection Doctor will show a green light for your SMTP if you have the SMTP Advanced Settings >> Authentication: set to none, BUT the mail server won't send the mail until the request passes the authentication process (changing the authentication settings to Password or the appropriate method will correct this).
However, with the information provided I can't pinpoint the problem. (What does Connection Doctor say after the green light? Do you use SSL?)
Oct 02, 2013 | Google Gmail
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
Hi my name is pandi.c i configure the mai id but smtp authentication error is occured any pls help me
Hi pandi ci smtp autthentication error occurs if the email id or password you configured is wrong or the smtpserver did not respond. the authentic email id should have the same extn as the smtp server
for example:
if your smtp server is smtp.gmail.com ten the authenticating email id should be xxxx@gmail.com.
the error also comes if the smtp authentication has been enabled. you can disable it and send docs without authtion . contact you sys admin . ok hope this helps u . bye
Narasimha kumar (INDIA)
Jan 19, 2011 | Canon iR 2016i Black and White Copier
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
I get sending error 0x800ccc80 when trying to send messages...But all messages are send once or twice a day at random times...otherwise they sit in the outbox
Outlook 2007 is stricter than 2003 about SMTP authentication. It could be the case that 2003 tried automatically to connect without authentication when authentication failed, while 2007 throws an error.
Please verify the settings for authentication in your account, and uncheck the box “My outgoing server (SMTP) requires authentication", on the "Outgoing Server" tab.
Mar 18, 2010 | Microsoft Office Professional 2007 Full...
Cannot Scan To E-Mail
yes, you can, go to brauser and type your bizhub ip aadress, you'll get a webscope page, there log in as administrator and under network choose e-mailt - smtp and there shold be a place where you can mark, that youre smtp server requires authentication.
May 05, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting up existing e-mail onto new pc.
wel smtp is your outgoing mail provider.
example.
email account kpn
internet account kpn
correct settings:
pop.kpn.nl
smtp.kpn.nl
email account kpn
internet acount xs4all.
this is the correct settings:
pop.kpn.nl with correct username and password
smtp.xs4all.nl
as you see you have to take the smtp address of your internet ADSL provider.
good luck.
Dec 06, 2007 | Computers & Internet
Secure Password Authentication (SPA), and SMTP Authentication
Yes, the P300 supports Secure Password Authentication (SPA), and SMTP Authentication.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Open Questions:
Microsoft Outlook 2010 Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
