Simpson ezyset 605 Please help my washer keeps baslling up my clothes out throwing the maschine out of balance in rinse and spin cycles, The machine is level and there seems to be no other obstructions or items stuck to be causing the out of balance. Can anyone please help me???
  • Rick Feb 20, 2012
    In a previous blog there was mention of the four supports that suspend the bowl, the washer that I have does not seem to have any adjustment on them as the comment suggested that the springs can sag over time? I feel it is time to upgrade.
catriver
  • 878 Answers
SOURCE: Washer overfills in rinse cycle
Kp, there was some models out there that had a issue with the timer. As long as the water is stopping during the initial fill I feel safe that you can rule out the pressure switch. You have already changed the fill valve. The only other thing is going to be the timer sending voltage to the valve. Part # 3955761 this is for the washer model number ending in 50LE0. Catriver..post back
Posted on Sep 11, 2006
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint bwm129 wont finish a cycle. super wash
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Posted on Dec 02, 2009
SOURCE: New Bosch Front loader washer Maxx Classic WAE18060AU
Remove the 4 transit bolts from the back of the washing machine. These are supposed to be remove during installation. If they are not removed the machine jumps around like crazy on the spin cycle and the machine is almost unusable.
Posted on Jan 04, 2010
  • 4090 Answers
SOURCE: not draining properly
The3 problem is more likely to be in the pump itself. No diagnostic except what you have jsut described. Open the outside covers and access the hose to and from the pump. More liokely on the inlet side and check the hose and the pump entry hole.
Please rate my help++++Thanks for using FIXYA
Posted on May 23, 2010
My Simpson ezyset 6kg washer won't empty or spin after it w eat out of balance
check the lever to microswitch adjustment for the balance
normally it is also the lid open microswitch and if the unbalance was sever enough the lever will be on the wrong side of the switch
Dec 27, 2016 | Simpson Washing Machines
Changed lid lock on a 750 simpson ezyset washing machine.
most likely a problem program board not moving onto the next cycle and that is why the lid lock is still activated
Feb 08, 2016 | Simpson Washing Machines
My washes machine spins to slow then gets off balance an stops.how can I fix it ?
It may not be the clothes but the suspension springs and rods, counterweights etc
see pics
Jun 10, 2015 | Simpson Washing Machines
I have simpson eziset 7.5kg has trouble spinning throws clothes to one side of tub
check that the machine is level
check that the wash bowl is level as a support mount may be failing and the bowl is not level
when it happens redistribute the clothes to a better balance point and re-spin
if it still happens ,seek the services of a washer technician.
Apr 07, 2015 | Simpson Washing Machines
Going out of balance
could be the springs are wearing out. some haier models I have seen start the spin at full motor speed, which could be part of the problem.
Nov 20, 2013 | Haier Washing Machines
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Will Only Rinse/Spin with little to no clothes in drum
sounds like unit is activating out of balance lever thats y it works with no load in it .possible faulty suspension rods making bowl move too much.out of balance lever is at back of inside bowl to the right. try adjusting back feet to make them about half an inch higher than the front feet .that will move the bowl away from lever giving more tolerence. see how u go please reply 4 more help
Mar 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
