Question about MTX RFL600D Car Amp
Is the mtx rfl600d amp 2 ohm stable on each channel.?
Its mono-block but it has 2 channels? i dont know... there no info online. if its 2ohm stable on bridged, wouldnt each channel be 2ohm stable too? anyone know. i want to buy mtx jack hammers 2- 12s but their 4ohm dvc
  • 32 Answers
SOURCE: 2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Posted on Feb 12, 2010
kcarmax
  • 30 Answers
SOURCE: i have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Posted on Mar 01, 2010
  • 66 Answers
SOURCE: how can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Posted on Apr 08, 2010
Testimonial: "yes that really helps thank you very much."
  • 417 Answers
SOURCE: I have a Kenwood kad-9104d mono amp hooked up to a
Usually a power rating is a power rating, 1000watt rating is a thousand watt rating. The amp will put out 900 watts at 2 ohms.
Posted on May 27, 2010
brianw74
  • 400 Answers
SOURCE: can you bridge 2 4
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Posted on Nov 22, 2010
How to wire a crossfire vr602 2 channel amp at 4ohm and 2ohm
I would be more worried about the amp than the speakers, those subs should handle the watts with no problem. The problem will be in the amps ability to remain working with a bridged 2 ohm load. It may not even stay on without going into protect mode with a 2 ohm load. If it does stay on then it may get really hot and shut off from the heat off of the Mosfett Transistors, or it could burn the Mosfetts from driving them too hard. Basically it's your choice, run your amp hard and gain more volume or run it with slightly less sound and have a cleaner sounding more stable amp that will stay on and have less chance of being damaged. If it's not loud enough the best thing to do is buy a different amp that better suits your needs and fits the application. In your case a 2 ohm stable Mono amp is going to be your best bet or a 4 channel amp bridged into 2 channels and run with 4 ohms on each channel. Or another exact matching amp like your 2 channel amp bridge them both and have each powering 1 of your 4 ohm subs. I used two VR mono amps to power my two 12" 4 ohm subs for a few years
Apr 03, 2013 | Crossfire VR602 Car Audio Amplifier
How can i bridge a mtx 9500 using a mono amp?
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
1 ohm stable?
YES IT IS i have the same amp and i have it to 1 ohm its powering to kicker l7's which are 2ohm subs down to 1 ohm stability
May 16, 2009 | MTX Thunder 1501D Car Audio Amplifier
Wiring options for amp
Te dual inputsm are tied together on the output side thus having a "MONO" amp. Most class D anps are stable down to 1 ohm (check your manuel) therefore, 2 2ohm subs are a 1 ohm load. 2 DVC (dual voice coil) 4 Ohm on each voice coil will give each sub a 2 ohm load so 2 dual4 ohm V's will give you a 1 ohm load as well. Parrallel all conections.
What subs do you have? Is this amp 1 ohm ono stable?
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 09, 2008 | Car Audio & Video
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
MTX RFL600D Car Amp Logo
44 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
