Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
REFRIGERATOR NOT COOLING OR FREEZING 1/2 WAY UP - CLEAN OUT DUST IN BACK
    Genius:
  • 1,122 Answers
If your saying the evaperator is only freezeing half way up then you have a freon leak or a clogged compressor dryer,-mike
Posted on Oct 31, 2008
Veggie freezing and ice cream too soft--how do I set the controllers? also water freezing in large drops in freezer
set the thermostat negative 15 if it is digital thermostat just press down if it is analog rotate it to clockwise the observe the cooling. try to clean your condenser maybe it has dust the air cannot circulate good also check the effeciency of your condenser fan maybe it has low rotation speed apply lubricants.
Feb 23, 2011 | GE GSS22SGM Side by Side Refrigerator
My 4 ton goodman heat pump goes into defrost and than after the cycle return in cooling stage at least the indoor coil starts freezing is the expansion valve working corectly
The reason for indoor coil freezing due to coil dust blocked-(Clean coil). 2. Less rpm of indoor f.motor. (Replace capacitor). 3. Short of gas. (Find leak and repair and then recharge gas.)
Jan 04, 2011 | Heating & Cooling
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
Not cooling flashing 3 code
a little more information would be helpful. what is the model and manufacturer of the refrigerator? there may be a legend to let you know what 'flashing 3 code' means. a few things you may want to check are: 1. if there are fans in the refrigerator make sure there is sufficient air flow space 2. be sure your condenser coils are clean and free of dust and/or grease buildup 3.see if your evaporator is freezing up 4.be sure the thermostat is calling for cooling and your compressor is running.
Mar 06, 2010 | Refrigerators
Not cooling or freezing. compressor and fan running
Hi, you say compressor and fan are running, you have 2 fans, a condenser fan motor in the back behind the panel at the bottom, and the evaporator fan in the freezer. When you check the condenser fan in back by the compressor, check the front of the coil to make sure it is clean as the fan pulls air through the coil to keep internal pressures down. You may have a sheet of dust on it. Check these things and get back to me. Keep me posted.
Sincerely,
Shastalaker7
Jan 30, 2010 | Refrigerators
My regfrigrator has not been cooling or freezing as well as it use to. Do I need a new part, or more coolant?
Maybe, but first remove the panel below the front door and clean out all of the dirt that is visible. Also, vacuum the back vents.
The best way to do all of this is to first vacuum what you can, the use the blower end of the shop vac and blow it out. After that, clean up the dust in the room...
Jan 02, 2010 | Refrigerators
For the second time this year my fridg is quit working. I is only about 7 years old. It is not cooling on either side. The ice maker is not freezing the ice very well it ends up freezing in lumps that we...
Check behind the fridge where the compressor is and see if the condensor fan is working,also clean all the dust out of the fan area eg condensor. Hope this helps Kind Regards.
Jul 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator stops freezing and cooling
clean it, check the bottom and back of the unit and blow/**** ,brush all the dust ,debris or cat hair or what ever is down there out.It could be just over-heating.
Feb 01, 2009 | Whirlpool Refrigerators
Xbox 360 freezing
Clean your disc, and keep objects away from the sides and back of the console... to allow cooling. Also might want to consider getting a cd lens cleaner, it'll get the dust out of there.
Dec 18, 2008 | Microsoft Xbox 360 Console
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
59 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
