Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Our Maytag Neptune washer does not drain completely.
Our Maytag washer does not drain completly. There is no visible water inside after a wash inside the tub, but when turning the tub, we could hear the water gushing around inside. What causes that and how can it be fixed? Thanks
  • 58 Answers
SOURCE: wash cycles are increasing in time required to complete
cold water valve in back could be plugged causing longer fill times.
Posted on Oct 31, 2007
Amigaman
  • 248 Answers
SOURCE: Washer will not drain properly.
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
Posted on Oct 06, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Error COde "nd"
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
  • 409 Answers
SOURCE: Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Posted on Sep 15, 2008
Maytag Neptune doesn't drain completely
check the inlet and outlet pipes to the pump there will probably be somthing stuck in it which stops all the water from draining out
Aug 24, 2012 | Maytag Neptune Washer
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
MACHINE WILL NOT DRAIN COMPLETELY THEREFORE IT SMELLS
No washing machine drains completely , there is always residual water in the hoses and heater sump
If the machine smells do a couple of hot washes with no clothes in but add a good dose of soda crystals dissolved in hot water.
Pour this mix into the drum before you start the wash
Try going back to old fashioned soap powders for a few washes , these contain some bleach and soda which kill of the fats left inside your machine by the normal 40 & 60 degree washes
Jun 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Feb 02, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
hi there,
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
629 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
