Question about Nintendo Video Game Consoles & Games
My wii remotes would not connect to my wii so I bought a new sensor bar and this did not fix my problem
3 Suggested Answers
cene765
  • 787 Answers
SOURCE: my wii remotes aren't working
First unplug the AC adapter from power cord and wait 10 min.Then plug it again and open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.Do the same for second Wii Remote.If this not help press and hold
the red SYNC button on the console for 15 seconds. This will clear all synced Wii Remotes from the console.Then try sync the Remotes again.
Posted on Nov 09, 2009
  • 51 Answers
SOURCE: i can connect it to my wii i need help connecting
wireless sensor bars do not need hooked up to wii........it only acts as a camera device......it only needs switched on
Posted on May 01, 2010
Wii remote will not work new batteries just blink all
Hey Jack, How many remotes are you able to connect at a time? If you have multiple remotes try turning the ones you know that work off, and putting them in another room(so you know they will not try to connect). Then try connecting with the bad one. If that doesn't work you might have to sync the remote: hold down the red sync button on the wii, located next to the sd card slot, while holding down the red button on the remote, located under the battery cover on the back. Now try connecting. If it still doesn't work, the LED lights in the sensor bar might have burned out, this happens a lot when you keep your sensor bar directly on your tv without the stand(the tv gets hot and burns out the lights), a lot of people do this because the stand looks bad. Go buy a new sensor bar, they sell them at wal-mart for $20, plus they're wireless, so you don't have to worry about that thin little wire popping. Test the new wii bar, if it's still not working, then you're remote is just worthy of getting returned.
hope this helps! -cj
Aug 21, 2009 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
No connection from remote to screen
Your sensor bar is definitely burned out, you can get a new wireless one at wal-mart for $20. Often wii sensor bars burn out because people put it directly on the tv instead of using the stand, the tv gets hot and the LED lights in the sensor bar burn out. If you want make sure that it's the sensor bar that's broken, get a video camera and video tape the sensor bar while it's plugged in and the wii is on, if you can't see four LED lights on each side then it's broken.
Jun 14, 2009 | Nintendo Wii Console
Remotes not picking up anything
I would suggest replacing the senor bar, it is not that uncommon that one the the Infrared LED's in the sensor bar to have burned out or go bad.
I personally use the wireless sensor bar after my original senor bar went bad
May 05, 2009 | Nintendo Wii Console
Wii remote not working.
Get some regular alkaline AA batteries and try your Wii Remote using them -- the blue lights on the Wii remote should light up and register with the Wii console (this is via wireless / bluetooth) -- As for the sensor bar, it is really only an infra red emitter - so if you have it properly connected to your Wii, the Wii Remote (with working batteries) can sense where it is by "seeing" the lights emitted from your sensor bar.
If the alkaline batteries work - You may need to get some new NiMH AA batteries to use in your charger - changers are usually third party devices; Nintendo does not ship charging stations with the Wii.
If the Wii remote appears to be working (blue lights and all) and your sensor bar is properly connected, you may have a dirty or damaged IR port. First clean the top of the Wii remote, just to make sure. If it still does not work, borrow a friends Wii Remote and check to see if it works with your system. If you do everything above and your Wii remote does not work while a seperate one does, the problem is most likely a broken Wii remote.
Jan 01, 2009 | Nintendo Wii Console
Wii controller cant connect to wii
is your wii remote sinced recently???
Dec 25, 2008 | Nintendo Wii Console
Problem with wiimote
the problem could be uv light, if its daytime make sure all the blinds are closed no extra lights are on near the sensor bar. if there is a glare on the screen at all it could be reflecting light to the wiimote as well. I've had that problem before myself, if that is not the case try moving closer to the sensor bar, make sure the sensor bar is connected correctly and then go to the system settings menu and calibrate the wii sensor bar and adjust the sensitivity, make sure you are not sitting at a wide angle from the snesor bar either, you can tip the sensor bar left and right in order to allow yourself a wider angle. also avoid using the nyko wireless sensor bar, it has a shorter range than the wired one that somes with the wii, mine came with a wireless on(used) and i just got a wired one and now it works much better. well I hope you find this info at least a little useful.
Feb 15, 2008 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Wii remote controll
Buy a new sensor bar. None of my 5 Wii remotes had a cursor on screen so I bought a new sensor bar and it worked fine.
Nov 12, 2007 | Nintendo NES Remote Control
Sensor bar / remote issues with Golf games
Has the sensor bar perhaps been moved? Is it becoming obstructed by furniture or something else?
Sep 09, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
