Question about LG RU-52SZ30 52" Rear Projection Television
TV shuts down
When I turn on my LG LCD Projection tv it turns off after 30 seconds and the indicator lamp blinks on and off. What should I do buy a lamp and how do I reset the lamp meter when I purchae the lamp. Will this really resove my problem.
  • 3 more comments
  • Anonymous Nov 10, 2008
    tv shuts down when trying to power...yellow lights just flashes an makes buzzing sound and shuts down.
  • domshelly Nov 11, 2008
    My tv when i turn it on the yellow light will just flash. I hear clicking noises and in about fifteen seconds the light goes red again. I already replaced the bulb, and that did not work what should i do no?
  • Anonymous Jan 04, 2009
  • jacknohi Jan 05, 2009
    My TV turns on, makes some noise for about a minute then turns off again. There is no activity on the lamp indicator, or on the temperature indicator
  • achretien Jan 13, 2009
    Genius:
  • 2,920 Answers
I would isend it to a shop and have them repair it
Posted on Oct 26, 2008
I got a 52" zenith
No,the tv message said replace lamp wright?Yes,mean the tv projection lamp is the causes and the problems.The tv projection lamp life span have ended that why the tv it is not holding a stable tv projection lamp picture.All throught these causes,does the tv make alot of clicking noises too,when the tv projection lamp is it on for 30 sec.and shut it self off?Yes,than the board that call the Ballast board it is also dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new tv projection lamp and a new Ballast board too for the replament too,if this tv causes have alot of clicking noises,when the tv is trying to ignite the tv projection lamp.
Aug 09, 2011 | Zenith D52WLCD 52" Rear Projection...
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
TV turns off after two minutes. Power light blinks for a few minutes then TV comes back on. Turning the power off after the set shuts itself off will cause the power light to blink five times for a minute...
5 blink indicates - AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
Jan 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Please help
That is the blink code for the lamp ballast. Here is the more complicated explanation from the service manual.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp is blown
Hope this helps.
Mar 31, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
Nov 14, 2007 | LG 52SX4D 52" HDTV
LG RU-52SZ30 52" Rear Projection Television Logo
196 people viewed this question
Computer Repairing
Computer Repairing
