Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I haven't got a answer to my Question
I have a. Yardman MTD 17.5. Brigs & Stratton 42" Deck it having a starting problem it will start to start then it will quit I checked the starter and it works it will. Also backfire when it tries to start, what do you think it could be
  • WMDM35 Apr 04, 2012
    Hi the Briggs & Stratton 17.5hp ws out of time when I replaced the timming pin it started but it ran ruff and when I got it to run good after it ran for a wile it shot oil and gas up through the Breather pipe tub so now I don't know what to do. Do you know what it might be. Thanks Walter Martin
    Sergeant:
  • 316 Answers
Hello W, to answer your question::there are only two things that will make a mower back fire,the fly wheel keyway is sheared and out of time,or there is a bent or bad valve,of it is a O H V engine the intake push rod will bend because it is aluminum and the weakest,hope this helps,,
Posted on Feb 20, 2012
5 Suggested Answers
  • 257 Answers
SOURCE: craftsman 22hp lawn tractor when its hot i loose
not a expert just trying to help,, sounds like you have heat problem with the carb or the fuel line,,make sure all the heat sheids are there,, if not repllace them,,cause it will cause the gas to try to vapor lock. hope this help you
Posted on Feb 17, 2010
SOURCE: I have a craftsman 25 hp 42 deck with brigs
apply a little oil under starter bendix gear and see if that helps.
Posted on Mar 25, 2010
  • 146 Answers
SOURCE: 10 A Fuse blows each time I shut off engine. Short
Yes, probably a short, and I think you should look at the ignition switch as the first suspect. It has two switches inside - one to send battery power to the various components, and a separate one to ground out the magneto when the mower is turned off. Could be a short between the two parts of the switch. Test it if you have the tools, otherwise try replacing it. Good luck! If this is helpful, please take a moment to rate my solutions, thanks!
Posted on Jun 10, 2010
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
I have a MTD yardman ridemower (Deck 42 in.)and when I go to start it it says that the deck is engaged if you could comment a picture of the bottom of your MTD 42 inch deck k it would be appreciated
none of my 3 mowers are smart enough to tell me the deck is engaged but from the picture you posted there is a belt missing on yours
May 10, 2015 | Mtd Garden
Remove deck from 2007 yardman 46 inch cut
Contact MTD if your manual doesn't cover this, or buy a shop manual.
May 18, 2014 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
What is the location of the oil drain plug on the Yardman 21
There is a 3/8" sq pipe plug on the underside of the engine. both Tecumseh and Briggs & Stratton used 'em. you may have to brush or scrape away debri from the mower deck and engine to find it.
Oct 09, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How do you replace the points on a brigs & stratton 5.5hp lawnmower engine
most newer mower don't us points and haven't in 20years most rough running engines are from dirty carbs
Apr 28, 2012 | Mtd Garden
I have a 97 yardman 20hp 46 " deck pto stays on in off position, slows down but doesnt totally disengage, any pointers would be greatly appreiciate it thx!
here is the manual bottom of page 16 and page 17, Good Luck Tim:
http://www.managemylife.com/mmh/lis_pdf/OWNM/99030004.pdf
May 29, 2011 | Mtd Garden
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Jul 02, 2009 | Mtd Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
