Question about Zebra 105Se Thermal Printer
Locking problem Hi, I am using this Barcode printer with LabView software. Atleast once in every day, the printer and computer is getting locked. When it happens, if I peel off a label it prints another label. When I turn off the printer switch and turn it on again after sometime, it takes care of the problem. Could you please give me a solution or give me an idea of the reason of the problem. Thank you. Regards, Urmila
  • bhmdis Jan 18, 2009
    my problem with zebra is : buton for pause is start every time
5 Suggested Answers
  • 31 Answers
SOURCE: label peeling
Sometimes the peel bar gets worn out and isn't very sharp anymore (replace). This will affect the peeling. Also try increasing the printhead pressure with the printhead toggle.
Posted on Jun 27, 2009
  • 13 Answers
SOURCE: The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Posted on Sep 05, 2009
  • 35 Answers
SOURCE: Hi,
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Posted on Feb 16, 2010
SOURCE: i need to print a barcode from labview
Follow this blog you will find a way to do this
http://extremetesteng.blogspot.com/
JMoreno
Posted on Apr 10, 2010
Ecu of pulsar 180
Hi, Krishna I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
ECU Unit Shoprider Deluxe Mobility Scooter Breaking Used Spare Parts
Engine Control Unit ECU Powered by LabVIEW
DOWNLOAD Bajaj Pulsar DTSi DTS UG 180 Service Repair Workshop Manual...
http://www.marutibajaj.com/pdf/Pulsar%20180%20ug3.pdf
http://ondoc.logand.com/d/1735/pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 28, 2014 | Bajaj Motorcycles
I have a Datamax DMX I-4212 Barcode Printer. Computer operating system is Windows XP. I use a third party software package, to produce barcode labels. The company is Argos Software. The printer is set as a...
Welcome to FixYa.
It shows that the printer is not communicating properly with the computer.
Solution:Uninstall the current printer driver from the control panel then re-install it.Your printer should came with a cd (software/driver/installer), use it to re-install the driver.
Thak you for using FixYa.
Dec 23, 2011 | Datamax DMX-I-4212 Label Printer
I require a .prn file for my cx400 for my software support person to design the barcode string to be used for my software to create the barcodes. my barcode printer is Sato CX400 & the software I am...
HI ...
1.I am using Sato CX400.my printer problem is when i give Command for printing copy (default by prn file one copy) but print out two copy and i wastage lots of label .so please help me about my problem.
2. i have sato Cx400 two printer but in both printer font is Bold & another is UN bold.so how make both printer setting same
Please help me by mail (bvionline@yahoo.co.in)
Thanking You
Jun 21, 2011 | SATO CX400 Thermal Label Printer
Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Jun 03, 2009 | Zebra Z4Mplus Label Printer
In using labview
import the media from the digital camera to your hard drive. Then convert it to a format that your software can understand. It should probably already be in JPEG format, and the software should be able to accept JPEGs already. Might be able to just point the software at the virtual drive that the camera becomes when you plug it into the computer, navigate through the directories inside the cameras drive until you locate the pictures, and select your picture.
Dec 12, 2007 | Microsoft Office Standard for PC
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 105Se Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
