Question about Hotpoint RVM1435 Microwave Oven
Microwave oven not heating
Motor runs; lights are on/ turntable spinning/ won't heat anything
Hotpoint over the oven space saver 950 watts
  • Anonymous Dec 19, 2008
    motor runs; lights are on/ turntable spinning/ won't heat anything
  • Anonymous Mar 14, 2009
    microwave not heating
Micro does not heat
Posted on Mar 02, 2009
WE have a JVM1650SHO5 space saver GE Microwave Oven that suddenly started not heating. No other issues.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
Light and turntable work, but it won't heat
There is a fuse in this microwave.The fuse is difficult to get to.
But i do not think it is this fuse.You have lights and the carousel
spins.This sounds like the thermostat or the magnetron tube that
creates the heat.
Feb 02, 2010 | Maytag MMV5156A 1000 Watts Microwave Oven
I have a Hotpoint Counter Saver Plus Microwave model RVM1435wd. The turntable does not rotate. How can I fix it?
If your turntable is not going around you may have one of two problems: the coupler under the glass tray may be worn and in need of replacement or the turntable motor needs to be replaced. Hope this helps.
Jan 24, 2010 | Hotpoint RVM1435 Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
GE XL1800 will not heat
sounds like the twt is bad (the traveling wave tube) that is quite expensive. Unfortunately your solution is probably to buy a new one.
Jan 22, 2009 | GE XL1800 1100 Watts Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave oven does not heat anything
heatman101
l;hkhtguii
Oct 13, 2008 | Magic Chef MCP13E1ST 1000 Watts Microwave...
Hotpoint RVM1435 Microwave Oven Logo
712 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
