Question about Kitchen Ranges
How do you remove the stove top element on a shacklock chef
Installed in house when bought, I do not have any details of Age and no Manuel. appears to be in good condition.
Demy
  • 20 Answers
SOURCE: Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Posted on Aug 01, 2007
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
aborcass
  • 2651 Answers
SOURCE: How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Posted on Nov 24, 2008
SOURCE: magic chef gas stove
i searched and never got one . so my solution is not to use the stove and be creative how i make suppers. so that is how i fixed it. do without and go on.
Posted on Jan 15, 2009
HOW TO REPLACE AN ELEMENT ELECTRIC STOVE CHEF CONTESSA
if its a coil element its easy
if solid or ceramic not so easy
CHEF CONTESSA as a brand of chef ran a lot of years
any chance of a model or build year for this stove
are you able to add a picture of the broken element
May 19, 2016 | Kitchen Ranges
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Shacklock chef manual
Usually (with oven unplugged) the burner will tilt up and is held in by a screw or 2 and has 2 wires attached (normally push on terminals). Have you read these with an ohmmeter to see if they are bad? The oven elements need the back cover removed and you will see the element connection and maybe a screw (if the screw isn't on the inside). It too should be checked for continuity before buying new ones.
Dec 06, 2013 | Ovens
HOW DO I REMOVE THE LOWER ELEMENT OF A MAGIC CHEF STOVE OVEN
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
Magic Chef CER3529AAH BAKING ELEMENT WORKS ONLY SOMETIMES
Most elements either work or they do not but at this age, it does not sound like there is a bad connection, it sounds like you have two bad elements.
You can get a small $20 meter at Radio Shack and test both elements if you want to replace them. Using the Ohms setting it should read 15-40 ohms.
Remember to unplug the stove, do not just turn the power off at the meter as someone could turn it on while you are working on it.
E
Nov 22, 2011 | Ovens
I have a shacklock multifunction twin- oven stove. Sometimes during cooking the digital panel starts flashing and the 'Auto' word comes up. Stove stops cooking and cakes are ruined unless I...
Hi - It will seem the electronics PCB is on the way out - it should be replaceable at what cost I cannot be sure. The best option would perhaps be to upload the actual model of the oven and its serial number & perhaps I can check on the F & P database if the parts are readily available.
If you can provide the details and country of abode I will see what I can do for you in regards to parts.
Jul 15, 2011 | Fisher and Paykel Kitchen Ranges
I need to remove the oven element. the plate that holds it appears to be riveted in place not screwed, unless screws are just worn (17 year old premier chef coordinate series).
These are screws you see. They are oxidized and the slots in the head are probably gone. Best approach is to spray with Pam (or equivalent) cooking oil, then use vise grips to remove the screws.
May 27, 2009 | Premiere Ranges EAK220 Electric Kitchen...
Magic chef gas stove
Jan 14, 2009 | Magic Chef CGR1420 Gas Kitchen Range
What is age span of stove?
I was using a 1938 model in an apartment unit and only replace it for the looks. Electric heating elements are cheap and relitively reliable..
Jan 02, 2009 | Magic Chef Ovens
Magic chef stove and oven installed 1978
Yes this is normal. you can use that burner to keep things warm without turning it on, saves energy.
Dec 14, 2007 | Magic Chef 9512 Electric Single Oven
Kitchen Ranges Logo
109 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
