Question about Frigidaire Ovens
LGGF3043KFM wont light - Frigidaire Ovens
Oven light wont turn off
make sure the door is shut tight and making the switch
Jan 04, 2014 | Maytag 30" Built-In Single Electric Wall...
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
My oven wont light . i had to slam door to get it to light and now it wont light at all
You need to get the igniter replaced. Don't mess with gas. Get it fixed.
Apr 21, 2010 | Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
The oven wont light. Panel light comes on and
Attach a amp meter to the ignitor wire. If you read 3 amps or less,replace the ignitor. 3 amps or more replace the gas valve.
Sep 06, 2009 | Ovens
Pilot light wont stay on
yes there should be a screw to turn near gas control knob at front there is one for each burner and the oven
Aug 26, 2009 | Ovens
Stave works but oven wont light,not getting gas
May be your ignitor. You'll need to replace this to get it to work. Hope this helps you.
Aug 14, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
