Question about Samsung Refrigerators
Samsung refrigerator rs25556sh manuel
Water inlet valve assembly
  • 1122 Answers
SOURCE: Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
Posted on Sep 22, 2008
  • 61 Answers
SOURCE: the solenoid on the water
you have the info rite / it is called the water inlet solinoid valve. this along with the mod. ser. # is all you nead to order the replacement valve. hope i was a help
Posted on Oct 20, 2008
  • 56 Answers
SOURCE: ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
Posted on May 30, 2009
milten1
  • 1304 Answers
SOURCE: water freezing in ice maker inlet tube
yes exactly,
follow your tube down to the water vavle you probaly have a small leak in the solonoid and it is dripping up
hard to beleive but it is
you can also turn down your freezer just a bit
but you will find the replacement water valve at the
www.appliancepartspros.com
just type in your model number
Posted on Nov 04, 2009
Testimonial: "Well written response. Doubt was anticipated which made next test exactly the right one to confirm the problem. A link for the solution was provided."
SOURCE: ge profile refrigerator slow water dispenser
you have a seperate valve for ice maker and water dispenser, though it is possible both could have debris preventing proper water flow, i would check the water pressure you have going into the valve solenoid housing. turn off water to fridge, disconnect the line at the fridge, not in basement at saddle valve. place end of tube in bucket, turn on water. how is pressure? good or slow? if its good, then you probably do need to replace valve solenoid housing. You can NOT clear debris out of these, they must be replaced.
If your water pressure is still not good, either y ou have a kink in plastic water line. Despite having changed saddle valve in basement, if the stem of saddle valve is mounted on bottom half of pipe, debris from pipe is getting into water line and so on. You can reply here or send me a question from my website: www.FixMyFridge.net
Posted on Mar 15, 2010
My Samsung RS261M is not producing much ice.. water is working just fine?????
Either the harvest temperature thermistor is bad or the inlet water valve is plugged or malfunctioning. More than likely, it is the inlet water valve assembly.
Mar 01, 2015 | Samsung Refrigerators
GE TPX24PBB make Ice but no water though the door
The water valve has different sides that control water to ice maker, water dispenser and through the water filter assembly. If one part fails you will need to replace the=> WR49X10043 Water Valve Conversion Kit found on the rear and near to the floor on the back of your refrigerator where the water enters the refrigerator.Another source is here=> WR49X10043 Water Inlet Valve Testing the valve can be done by watching the instructions in the video above Refrigerator Water Inlet Valve Testing If you have questions please respond to this post, Thanks Sea Breeze
Jun 27, 2013 | Refrigerators
Nowater to ice maker
That is most likely the=> DA74-40149D Water Inlet Valve providing your model is a Samsung RS2630SH being defective on the ice maker side of the DA74-40149D Water Inlet Valve
Not your model number? Let me know, Thanks Sea Breeze
Mar 21, 2013 | Samsung RS2630SH Side by Side Refrigerator
Water won't come out of dispenser. ice works fine
Your refrigerator is equipped with a dual water inlet solenoid valve assembly . It is likely that the solenoid valve that controls flow to the water dispenser is faulty. Click here for a tutorial on How to Test Inlet Valve.
Feb 11, 2011 | GE Profile Arctica 25.4 Cubic Feet...
My new (2 months) Samsung refrigerator barely dispenses water. It just trickles out. It would take 5 mins to fill a 20 oz glass. The ice works fine (good water flow to it). The water filter is fine....
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Mar 29, 2010 | Samsung RS2534 Side by Side Refrigerator
No water/ice
HI. First, you will need to rule out any standard issues that will cause this. Check the internal, and external feed lines for any obstructions. Make sure that the internal lines are not frozen, or kinked. If the lines check out ok, move on to the water filter(if equipped).
In most units, there will be a filter, present. These devices are set to operate on a particular time frame. If their filtering limit is met, the filter will stop filtering water, thus, not allowing the fluid to flow, at all. Make sure that the filter is up to date. If you have verified that the filter is ok, move on to the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Jan 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
The icemaker isn't working. The water line is hooked up and working fine when I want to get water, but the line isn't feeding water to the icemaker in the freezer.
HI. testing is needed at this time. There are some issues that concern the operational value of the inlet assembly. check the lines to make sure that they are not frozen. If the line that feeds the ice-maker is ok, and not frozen, proceed with the testing of the inlet assembly.
Nov 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WATERS NOT COMING OUT
Possible reasons:
Water lines frozen.
Defrosting the fridge completely will fix the problem.
Inlet valve at the back of the fridge faulty or blocked.
Replace or unclog main water inlet valve.
Water valve or solenoid in water dispenser assembly faulty.
Replace or fix water valve or solenoid located in water dispenser assembly.
Sep 04, 2009 | Samsung Refrigerators
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
My 7 year old Kenmore refrigerator is not dispensing water and ice.
HI. there are only two reasons for this type of issue. One would be a frozen water supply line and reservoir, and the second reason will be a faulty inlet valve assembly. IF you are certain that the lines are not frozen, i recommend replacing the inlet valve assembly asap.
Use this procedure below to test the valve.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Aug 24, 2009 | Refrigerators
Refrigerators Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
