Question about Swimline DOUBLE ACTION MANUAL PUMP
Pump is leaking water from the bottom of it
Bestway action spa pump model num 54075
    Top Expert:
  • Swimline Master
  • 5,743 Answers
Bad seals best fix replace whole pump
Posted on Nov 05, 2017
Bestway Lay-Z-Spa
We sell the Bestway Lazy-Spa however we do not sell anything other than the replacement filter so I cannot tell you what is all included with that part number.
I would suggest you contact the store you purchased the spa from to determine the contents of the replacement item.
Rod
US Parts Center
Feb 12, 2014 | Pool & Spa
I have a lazy spa pump which seems to be leaking from inside. Have looked and cannot see anything obvious. Any ideas please?
most of the time it's the mechanical shaft seal that leaks do to age or damage might be a tuff fix on this pump
Aug 02, 2013 | Intex BESTWAYS 12X30 FAST SET POOL
Lay-Z-Spa pump impeller replacement
In order to find the proper replacement you will need to provide someone with the following information.
  • amps
  • voltage
  • discharge size pipe
  • suction size pipe
Rod
US Parts Center
Jun 01, 2013 | Home
Lay z spa pump impeller replacement
Perhaps an inquiry of Lay Z Spa will yield an answer
Jun 01, 2013 | Home
Timer on chlorinator will not go on after 24 hours
The 24 hour timer is probably faulty and needs to be replaced.
Jun 04, 2012 | Bestway Usa Type 2 or II Bestway...
I have a flowclear model 58144 and it got turnned on before water was ran thur it and now it wont turn on what can i do its only a week old
Take it back to the store or call bestway support, they put out a bad batch or something with a bad timer. I'm about to get my 3rd one from the company all with the same problem. I suggest you get a refund on it and get an intex chlorinator from Walmart. Cheers!
Jun 05, 2011 | Intex Easy Set 530 Gallon Swimming Pool...
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Aug 02, 2010 | Pool & Spa
I need a user manual for a bestway pool filter pump model 58085
Are there a number on the side that u can call? Thats how i got my manual for a sta rite pool sand filter and pump. I couldnt find it anywhere online but once i called them they gave me the link that took me right to it. So maybe if u call the 1-800 number located on the filter pump they may be able to help u.....Good Luck!
Maybe this link is your pump check it out
http://www.bestway-uk.com/downloads/Manual_FilterPump_58117_58118.pdf
Jun 27, 2010 | Pool & Spa
Swimline DOUBLE ACTION MANUAL PUMP Logo
97 people viewed this question
Top Swimline Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Swimline Pool and Spa Expert? Answer questions, earn points and help others
