Question about Samsung HCL4715W 47" Rear Projection Television
How to get rid of blue ghosting
The blue ghosting seems to get worse the longer the tv is on
  • Samsung Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerHow to get rid of blue ghosting - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Posted on Apr 18, 2010
Starting last night our tv has had a "ghost" thing
What you have is a very common convergence issue which could either be rather spendy if you take it to a technician like me. It usually costs approximately between $300-$400 if yo bring it to someone who knows what they are doing OR you could go to and order the convergence repair kit for about $75-$80. Ed will set you up with the resistors, the integrated circuits, thermal paste, and step by step directions. It would take a novice about an hour and a half to complete the repair and you would save yourself some money. Sorry, there is no scan option to fix it.
Dec 01, 2010 | Sony KP-51HW40 51" Rear Projection...
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
GB4308 Ghosting
The cost I don't know, but this can be fixed. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Jan 02, 2009 | Apex Digital GB4308 43" Rear Projection...
TV has double picture. Ghost shadow is Blue.
looks like the t-con board failing, or a lose connection to the t-con or screen ribbons off the t-con board to the screen.
tcon-y0wguvybehhtyrwlmlutw4ro-5-0.jpg its fitted to the screen back under the shield will look similar to this.
Dec 28, 2017 | Mitsubishi WS-65511 65" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Ghostly image with more Blue in Picgture
Yes you need to replace both STK392-040 convergence ICs. You can get new replacements at the following link and they provide free instalation instructions with pictures so you can do the repair yourself in about an hour. They alos have free online instant messageing available to all there customers. heres the link.
May 26, 2008 | Samsung PCL6215R 62" Rear Projection...
Blue violet ghost
did you just replace your lamp? your balance is probably off.
Jan 31, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hitachi tv, model 53udx10b
Sounds like you need to run Magic Focus.
Sep 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
