Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Random Blue Lines
I have much the same problem as another person did on this page. 1. When the T.V> is plugged in it come on automatically. 2. There are blue lines racing all over the screen (like x'sfrom one corner to the other) looks like the old Vsync. 3. No volume / menu / video select will change but still blue lines everywhere other than one setting. I have pulled out the power supply board and saw the 3300 uF capacitor mentioned in the other post but was not sure that it was bad / not leaking. not sure where the pico fuse is exactly as i have no diagram and not much exp working with TV's. I found that the power supply was available from www.bestbuy.com for 69$ but wanted some opinions on this before i spend money i dont have to spend. Do you think replacing the power supply will fix this or have you ever seen this before? Thanks in advance. sorrowfull APEX T.V. owner...
  • Mark McGill Aug 22, 2006
    O.K. The voltages are listed there on the board. I will measure them tonight and if any of them is off then I guess without a doubt it should be the PS. I also found a circuit diagram of it as well. I will let you know what I find.
    President:
  • 3,130 Answers
You should'nt replace anything untill you get a multimeter and measure the voltages on the Power supply PCB. Call Apex in your owners manual and see if they will supply a service manual so you know what the voltages are suppose to be. Or that manuel is avail as a download at http://www.servicemanuals.net/ for 15.00 bucks! Then you will get a better idea on what needs to be done , instead of shotgunning the repair. Good Luck
Posted on Aug 22, 2006
SOURCE:
The Drive light flashes and the car loses power and sometimes won't start.
It is either your Vehicle Speed Sensor (easy to change) or your Automatic Transmission Computer (capacitors burn out on these boards, there is a fix for this too, the picture is at the bottom of this page). You need to diagnose by removing the lower right plastic kick panel on the passenger side. There you will find a blue plug. With the car OFF stick a paper clip, wire or stuff the plug with foil to make electrical connection so that the two terminals are touching. Then, turn the ignition to ON (not enough to start it though, just power it up). When you do this, count the blinks in the "D Light" or count your blinking Check Engine Light. Both are different but can refer to different things wrong with your car. A long blink is the first number and the short blinks that follow are the second number.
So imagine this as being 14 : ___ _ _ _ _
Below is a decoding chart:
The first section will be the check engine light codes, the next one is the Transmission Control Unit Codes read from the D Light;
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
TCU Codes:
CODE LIST:
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
Feb 14, 2010 | 1992 Honda Accord
1991 accord, auto trans: green sport light is flashing. WHY???
It is either your Vehicle Speed Sensor (easy to change) or your Automatic Transmission Computer (capacitors burn out on these boards, there is a fix for this too, the picture is at the bottom of this page). You need to diagnose by removing the lower right plastic kick panel on the passenger side. There you will find a blue plug. With the car OFF stick a paper clip, wire or stuff the plug with foil to make electrical connection so that the two terminals are touching. Then, turn the ignition to ON (not enough to start it though, just power it up). When you do this, count the blinks in the "S Light" or count your blinking Check Engine Light. Both are different but can refer to different things wrong with your car. A long blink is the first number and the short blinks that follow are the second number.
The first section will be the check engine light codes2_bing.gif, the next one is the Transmission Control Unit Codes read from the S Light;
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
TCU Codes:
CODE LIST:
Feb 14, 2010 | 1991 Honda Accord
I have a 92 accord. Automatic Trans... Doesnt move.
The first section will be the check engine light codes2_bing.gif, the next one is the Transmission Control Unit Codes read from the D Light;
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
TCU Codes:
CODE LIST:
Feb 13, 2010 | 1992 Honda Accord
When i print a page black ink text thin blue lines appear also a blue ink blob
Method 1:Remove your colour cartridge wen you require only balck ink[The blue lines are often signs of empty cartridge]
Method 2: while printing select 'Use Black Ink Only'
Oct 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
ON Lexmark C510: On left edge of paper, I have small lines
your copier scaner mirror is dust over clean it then solve it
Jun 25, 2009 | Lexmark C510 Laser Printer
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
67 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
