Question about HP Photosmart 2610 All-In-One InkJet Printer
Hp2610 lights blinking error message
Read your posting and solution for another user. I have a similar problem (after a lightning storm) But our unit is not connected with a USB. Should I try the same fix?
  • 558 Answers
If it is connected with USB to PC then you can try it out!!
Check out also for any jam caused by paper or cover firmly closed..
A hard reset by unplug do the trick most of time in printer to run. Let me know if it not..
Posted on Oct 27, 2008
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
Jan 01, 2016 | Building Materials
Blinking yellow light
According to the manufacturer's users guide, a flashing Yellow LED means that there is a message for you. You are instructed to sign in to your account to read the message. Apparently this is not to be construed as an error indication. See link for Users Guide.
Users Guide - See page 7
Nov 09, 2013 | Seagate FreeAgent DockStar Network Adapter...
Tv keeps shutting off without warning
Hope Bob C does not mean computer_Bob who used to be a expert here.
To address your question:
If no error blink code exists (power light or other blinks a specific number of blinks) it likely is a issue in the power supply of the set which usually will give an error blink code of some type.
Common failure reasons include but not limited to:
Yes, dirt inside (dust to be kind) will trigger shutdown etc.
A lamp will usually before it fails give some indication like a dimmer picture but dirty fans and dust inside can also do this.
In our shop if it is dirty inside first thing is it goes out the door and gets a good dose of compressed air--usually looks like a dust storm.
Lamp life is on average 2,000 hours (average user it is 2 years) and generic lamps have a lesser life.
Ballast usually is suspect if several lamps have failed in a shorter period of time but can just fail.
These are my thoughts from working on this and similar sets--what have you tried so far?
Apr 30, 2012 | Sony KDF46E2000 46" Projection HDTV
The tv just turns off after about 5 seconds and won't stay on. i've used the system reset and unplugged it already. no power surge, lightning storm, etc. Ideas?
If reset does not cure it and if after about 70 seconds of unplugging set the green power light stops blinking, do this:
When power light comes on and goes off, on the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and RELEASE both buttons.
Power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code you find and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
Aug 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Blinking standby light, dead dvd player
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Jul 13, 2009 | GPX D1816 DVD Player
Craftsman garrage door opener not operating after thunder storm
If you had an lightning storm you most likely have a bad logic board. That is not a reset button you are pressing.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Blinking light wont turn on Toshiba TV CE19H15
Yes, it's quite possible that you indeed may have sufferd from a Power Spike, induced by lightning during the storm, esspecially if plugged in during said storm. I have had quite a few customers ova the years with this exact problem. I always advise my clients to unplug ALL devices during a storm, and for ones that simply cannot be unplugged then some sort of Spike/Surge Protection device MUST be used. As a matter of interest, I have written many a report to insurance companies to support a claim for a replacement.
Aug 08, 2007 | Toshiba 19A26 19" TV
HP Photosmart 2610 All-In-One InkJet Printer Logo
62 people viewed this question
Ben Johnson
