Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I need a wiring schematics for 17.5 42
I'm having with it starting it will crank yhe stop then when you bump the starter it will start then stop it will also backfire so what can I do
    Sergeant:
  • 316 Answers
Hello,, To get parts or manual for your craftsmsn,sears,kenmore product,type in sears parts direct.com in yahoo or google search box and click,when screen comes up click sears parts direct in bold letters, when screen comes up enter the model number in box,click type of search you want,than click GO,your parts list or diagram will come up than find the part you want and order.hope this helps, ~~
Posted on Feb 20, 2012
Do you have a wiring schematic for the starting system on a 1994 Ford 4630 Diesel Tractor?
Randy, Check the attached link and scroll through it, hope it has the info. you need.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1994 Ford 4630 Diesel Tractor wiring schematic for the starting system...
Apr 22, 2016 | Ford Cars & Trucks
How do i get rid of engine code 13 on my 1992 Lexus LS400
You change no parts
The only parts that get replaced, are
those that fail a test
Have a repair shop take over & find a problem
thru proper testing vs: a wish & hope strategy
on a guess, by replacing good parts
Nov 21, 2014 | 1992 Lexus Ls 400
I hit a bump and my car cut out and now it won't start, what could this be?
maybe a wire jumped out from the starter check an electrician...
Dec 29, 2012 | 1994 Chrysler LHS
'98 sierra, k1500, 5.7 won't start until cold crank for 15 seconds
COuld be some problem with the starter, sometimes, when the starter warm, occurs this no start condition.
Aug 23, 2012 | 1998 GMC Jimmy
88F250 4x4 5.8L FI 5 speed. A friend has this & the starter went out. I replaced it & the solenoid. No big deal right? I returned it & the next day he called me & told me that the...
Its a solenoid...it engages the bendix and truck starts...bendix should retract because power to it gets shut off by ignition switch going to "run".
Only way bendix would stay engaged or get a signal to keep turning ???
Bad contacts in ignition switch...maybe ??
Start relay in under hood power distribution panel has hot or welded contacts ?
I've gotta think about this one...hope this gives some help...
Jul 30, 2011 | Ford F-250 Cars & Trucks
I keep blowing fuses when I try to start my 883. After tracing wires I can't find a dead short anywhere. All the lights and horn work fine. Only when I hit the start switch does it POP. I have checked...
Do not put a bigger fuse in the slot. If you do, you'll just burn up your wiring harness. A fuse is there to protect the wires. The fuse does this by blowing if the maximum current capacity of the WIRE it's protecting is exceeded. If it's blowing the fuse ONLY when you press the start button, it's in that circuit somewhere. I'd pull the starter relay and try it again. The relay is on the backside of the oil tank. You'll have to take the seat off to get to it. If it blows a fuse then, the problem has to be in the wire that comes from the start button going to the relay. If it does not blow the fuse, buy an new relay and install that. If it starts blowing the fuse again, you'll have to look at the schematic and find out where the wires go and trace them out. If you aren't getting any voltage at the blue wire, pull the relay and do a continuity check from the end of the wire where it plugs onto the starter and the frame. Pull the wire off the terminal on the starter and test it. If you have continuity, you have a short somewhere in that wire. Contact me directly at wd4ity@bellsouth.net and I'll send you a schematic. Remind me of what you need.
Good Look
Steve
Jun 27, 2011 | 1993 Harley Davidson XLH Sportster 883
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
I need a schematic for my 1998 Dodge pickup diesel
you have a direct short in the main starting line,ie the battery to the starter or the starter wires take a very good look and you will find/see the problem it will be a main red wire touching ground/earth.adrian,,
Jul 30, 2010 | 1998 Dodge Ram 2500 2WD
How do you find top dead center?
Locat #1 cykinder, remove the spark plug, Put a piece of cleanex in the plug hole and bump the starter. When you blow the tissue out, your piston is on the compression stroke. bump the starter, not crank. If you go to far then go aroun again When the piston is in up stroke compression, hand thurn the crankshaft until the piston tops out and starts going down. back it up so you are on the upstroke agai. then forward again until you crest again. Look on yhe front crank pully for timing marks line them up when you have #1 near its top.. The cylinders are numbered oon the manifold. Good luck
Jul 10, 2009 | 1996 Ford Taurus
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
