Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
I have a fridgerdire freeze that has not beem used in a a while. We plugged it in today and I have a power light and a temperture alarm. When I turn the freezer on I hear a buzzer alarm going off and the only way to stop it is to tun the freezer off using the off/on switch. Is this freezer a dead unit or can you help US. Thanks Jim Stanton
  • Kenmore Master
  • 19,396 Answers
Hi James.
Most Kenmore upright freezers use a backup battery located at the lower part of the appliance. When the battery is low the freezer will beep continuously. If the unit has been off for a long time, and if the unit uses a battery, then the battery may need replacement.
Here a picture of the battery in its housing, located in the lower front part of the freezer.
I have a fridgerdire freeze that has not beem used - 2_19_2012_11_19_52_am.jpeg
Posted on Feb 19, 2012
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
I need an online manual for proline freezer CF6 37P see drection for temperture control
there a alarme light showing on my chest frezzer what dose it mean
Aug 02, 2011 | General Freezers
Making alarming buzzing sound. Still freezing fine
putting unfrozen food in a freezer can raise the temp to cause it to go off allow 24 hours for it to stop if it dont replace the buzzer
May 23, 2010 | Whirlpool Upright Freezer EV161NZRQ
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Indesit c239 freezer not getting cold red light constantly on
If you take the rear cover off the inside of the freezer you can see the evaporator coils. observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 15, 2009 | Freezers
FROST AND ALARM LIGHT ON
Your defrost timer, switch or circuit board is probably shot or it would be defrosting.
Use a fridge / freezer thermometer to tell if temperture high (it should be 0 F plus or minus 5 degrees) to determine if it is too high - this is normal if frost builds up but will get worse unless repaired.
May 04, 2009 | Hoover Freezers
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
