Question about Sony MDS-E10 Mini Disc Player
MDS-E10 Problems loading and ejecting discs
The system plays and records fine, but the system does not load or eject the discs without prodding or tapping the case to release, what seems to be a stuck moving part inside that, raises and lowers the disc into playing position.
Is this a repairable part? If So which part needs replacing, and approx how much?
This was a an expensive pro quality device I cannot junk it.
Hope you can help me.
Dave.
  • Dave Bliss Mar 03, 2009
    No this did not fix it. The mechanism is not loading correctly. I suspect a broken drive on a small motor actuator, or similar.
    Anybody else got any ideas or maybe Sony UK service telephone number?
    Best wishes.
    Dave.
    Dear MDS E10 user,
    I had a look at taking the play back and record assembly apart, it looks like a nightmare for clumsy fingers like me.
    Just what sort of loot are you wanting for the parts?
    Dave.
    blissmusic@hotmail.com
Hi, its probably way too late to give this solution but there is a ribbon cable that runs from the main board onto the display board that causes this problem. Its very accessable from the top and all you have to do is pull it out clean the contacts and re-seat it. This will resolve all sorts of communications issues with the display and buttons.
Posted on Mar 03, 2009
  • anthony542 Mar 03, 2009
    Well i have a MDS E10 if you want the mech out of it? The record head on it is shot but it plays back fine. Let me know..
    Thanks
I have a tascam 564 i,m unable to eject the disk from the machine it only reads disc loading
I listed a similar answer for a similar qestion. If you have a push in to load mechanism, it is probably worn out. I had similar problems and found they were impossible to correct - think of it is an out of allignment or mechanical problem.
The few places which can fix this problem were charging $60 an hour plus shipping to and from, and may not have the parts to fix it. the cheapest way to go is to eBay for another MD.
If you are buying a used deck check it out like this - Load and record a good disc. Eject it and then replay it. If the reloaded disc plays you have a good MD if not you have a bad MD recorder of some sort.
Bad decks act like they are recording but MDs are not CD recorders they use a laser and a magnetic riding skate on the other side to of the MD write to the disc. If the skate is damaged they will appear to write but when you put the disc in another recorder or reload it to your recorder they will not have anything recorded on them.
I get bothered when I see clueless ads for used MD recorders saying it plays but does not record but it is a simple fix - It is not and the unit although it will probably play well it is not cost effective to fix the record problem I mentioned.
Feb 24, 2014 | Tascam Audio Players & Recorders
MDS-E10 failed to record
If you recorded a disc and then the deck saved it; then you cannot play it is probably a bad mechanism. When I buy old decks I check them by inserting and recording a disc then ejecting it. If it will then not play when reloaded the deck is bad. Often the decks say they are saving but are damaged and cannot so this is the only way to know for certain.
Jan 27, 2014 | Sony MDS-E12 Mini Disc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
MDS-E10 will not eject disc
The lower end mechanism were full of problems after about a year of use. The unit needs to go to an appropriate Technician- NOT Sony as they will just replace the mechanism if they even work on it and it will be the same cost of a new unit. The mechanism you have needs lubrication and a limiting resistor placed in line with motor to not break plastic parts.
Jan 27, 2013 | Sony MDS-E10 Mini Disc Player
Any disc inserted just gets ejected
Either the loading is not completing of the mechanism or the laser pickup lens is dirty.
Dec 05, 2012 | Sony Vintage Mds-101 Compact Chassis Mini...
My sony mds-303 is ejecting new disc and saying disc error
I had the same problem. Take the top off and wind the loading wheel until the mechanism engages and loads - but with no disc in place. Then unplug the power and look through the top. You will see the lens. Clean with rubbing alcohol and a q tipi and dry with a clean q tip. Try playing a disc
Mar 26, 2012 | Sony Audio Players & Recorders
UPON EJECTING THE DISC FROM MY MDS-JE440 IT IS WIPING ALL DATA AND BLANKING OUT THE DISC COMPLETELY ! IT HAS ONLY STARTED DOINING THIS IN THE LAST DAY OR TWO AND I'VE LOST MUSIC OFF 6 DISCS COMPLETELY, SO...
I think your recording head failed, you should stop using the deck and get a similar used one which works, repairs are usualy not cost effective.
Prodigital in Philadelphia does repairs, I paid about $250 for a replacement loader unit installed + shipping.
Feb 09, 2011 | Sony MDS-JE480 Mini Disc Player
Hi have an mds-je500 minidisk player that stopped accepting disks, worked perfect one minute, says load error next each time i try to load, then says eject even though disk doesn't go all the way in....
The small limit switch for the disc in position typically goes bad on about 40% of all Sony Minidisc recorders. It is a $5 part, but will probably cost you $35 to get it installed.
Nov 05, 2010 | Sony MDS-JE480 Mini Disc Player
I have two rack mountable minidisc players can any one in the world fix these things(frustrated).An MDS-E 12 & an MDS -E 10.One just fell over backward from the ground in a wooden rack. The other electric...
I have repaired a number of these over the years, the main problem is usually the loading mechanism or the optics. Neither is cheap. Where are you located?
Dan
Jan 23, 2009 | Sony MDS-E12 Mini Disc Player
Sony MDS-E10 Mini Disc Player Logo
354 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
