Question about Plumbing
French doors to outside
Reoccurring problem with floor rotting out where door opens.Professionally repaired last time, also now involving molding on inside of door.
Can you clarify a bit more. i am qualified carpenter
Posted on Feb 19, 2012
How do you fix a rotten floor by the door on the camper
Hi Harold:
There's the crude and the fancy.
crude is to screw a piece of plywood over the rotten area so you don't fall through.
Fancy involves taking your time, removing the floor covering, and then cutting out all of the rotted parts.
Then you have to fabricate replacement pieces that can be spliced (glued and screwed) to undamaged parts. Then install new floor sheathing, and finally new floor covering.
Ta Da!
Feb 07, 2016 | Cars & Trucks
LG 2014 French Door bottom freezer
Possibly the weatherstrip around the doors. Has this always been the case, since the first use?
It's possible, too, that you have a slight obstruction that's keeping the doors from closing fully. They SHOULD seal completely. If they don't, you may have a problem with fast frost buildup, and the defrost timer may not be able to keep up with it.
Jul 29, 2014 | Refrigerators
French refrigerator has green mold in refrigerator under metal p arts that I can't get to or clean
Children do not create mold or germ problems. Try to make a cleaning tool that does reach into the area, perhaps bending a long metal spatula or a barbecue brush.
Dec 14, 2013 | Computers & Internet
How to check Saab 9-3 inner door membrane
`Your door has drain holes on the bottom. Poke a stick up them to make sure they're not plugged. I think you'd hear the water sloshing around if enough were to accumulate to drain into your floor. The membrane is a plastic water shield, glued to the door frame just behind the panel. It just provides a water-tight seal for the electrical switches and connectors in back of the door panel, and to prevent door panel from rotting or getting mold. Water and moisture get into the inside of door from rain on outside of glass. Should drain out the bottom. The membrane just protects back side of door panel and the electrical stuff.
Hope you find where it comes from.
Dec 28, 2012 | Cars & Trucks
Why wont the rear door open on my 2009 gmc acadia
from inside or outside ? if won't open from inside your child safety lock is probably tripped. if won't open from outside you probably have a lock rod that popped off inside the door, in which I would have the dealer fix it, it involves taking door pad off and when you can't open door to take pad off ,most of the time it damages it.
Mar 19, 2012 | 2009 GMC Acadia
I have an old hotpoint oven model rb525j2. I am trying to repair the door gasket. I have the part, the old one seems to be rotted away in the seal and I have no idea how to take the old one out, much less...
Most ovens have 4 or more screws, that tighten the inside and the outside of the door together--
Also-- Most doors can be removed, and laid on the floor, or on the bench--
Either way The door needs to be in a location you can get to those screw.
Separating the inside from the outside will allow access to the glass, and the door gasket.
Let us know what you find when you get this far..
Mack B
Dec 27, 2010 | Ovens
I want to adjust the upper doors on a viking french door model vcff036ff. The left door is higher than the right door. It appears that I have to remove the door to adjust it. Dan
USE A SPIRIT LEVEL ON THE OUTSIDE OF THE UNIT FIRST,IT IS POSSIBLY THE FLOOR THAT IS NOT LEVEL.........USE SPACERS UNDER THE FEET......factory build them square.....
Jun 07, 2010 | Viking VCFF036 Bottom Freezer French Door...
Im getting water under my carpet on the drivers back rug.alot.mold is growing.also when i open the driver front door i see water on the jam.is that sunroof related or door related?
Best way to check is with someone on the outside with a hose and someone on the inside looking for where the water is getting in. Repairs may involve adjusting the weatherstrip or the door. even the inside panel has a water pad it can be missing or partly uninstalled The windshield can be leaking, or the cowl drains are stopped up with leaves and dirt. The hose should find the problem
Nov 02, 2009 | 2003 Volkswagen Passat
Maytag french door bottom freezer (does NOT have water/ice dispenser on door). There is moisture on the door seal - the movable piece - which ends up dripping on the floor every time you open the door. ...
You have a seal problem around the door or the heat strip inside the frame to prevent this is not working. Or both. So you are sure the model is the MFD2560HES. Let me know if you want me to help you solve this, Sea Breeze
Jun 11, 2009 | Maytag MFD2560HES Bottom Freezer French...
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Plumbing Logo
27 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
