Question about Canon ZR700 Mini DV Digital Camcorder
Error condensation i can't resolve this. The camera doesn't load the tape. :(
2 Suggested Answers
Rick Riggins
  • 1812 Answers
SOURCE: I haven't used my Canon
This is usually caused by a failed component in the moisture detection circuitry within the camera. This will require disassembling the camera to remove the tape mechanism and repair. This can usually be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 12, 2011
I haven't used my Canon Gl2 since last during the winter months. Camera was used for filimg in the snow. As of today I pulled the camera out of the case. The camera powered up when I turned it on to...
Sep 12, 2011 | Canon GL2 Mini DV Digital Camcorder
Condensation
Camera has a sensor inside to detect condensation
Condensation can occur if the camera is moved from a cold environment to a warm one.
So open the tape compartment, remove the tape to allow maximum airflow and wait for the camera to warm up
Regarding Condensation please wait
This message comes when your camera hasn't experienced a sudden change of temperature, this could indicate a possible fault.
Thanks for using Fixya
SAM ANDERSON
Sep 22, 2008 | JVC GR-D50 Mini DV Digital Camcorder
I have a Sony HDR-HC9 that for some reason gives me the error code "C:31:22". I get the error every time I put a tape in and it wont let me do anything while the error is occurring. But when I...
This is a fault in the tape transport system can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a dislodged pinch roller or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Jun 22, 2011 | Sony HDRHC9 Mini DV Camcorder
I have a ..tvr608 hi 8 camera..the code c:31:22..i tried removing tape and letting sit open for 24 hrs to dry (per manual) nothing..any suggestions??seems like " tape drive " is slipping..if...
Hi
Thanks for using FixYa. Error C 31:22 is caused due to bad Gear assembly, to resolve this issue with the battery &cassette removed try whacking the camera sideways, if after doing this still the issue is not resolved then you’ll have to get the Gear assembly replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Sony Video Cameras
Condensation please wait constantly appears on the screen unable to do anything the camera seems to shut itself down it wont even let me load a tape in.it wont record playback nothing.
There is a "dew" sensor inside that is preventing the unit from accepting the tape. This is a safety feature to prevent damage to the tape. If there is any moisture inside, the tape will stick to the heads and get damaged. Open up the unit (eject) and point a hair dryer toward the opening with the dryer about 12" away. Let the warm air flow for 10 minutes or so and try the camera again. If that failes to resolve the problem, then either the sensor is defective or the connections to it are defective and the camera should see a servicer for repair.
Good luck,
Dan
Nov 05, 2009 | JVC GR-D70EK Mini DV Digital Camcorder
Sony dcr-trv270e camcorder not loading the tape
problem resolved by .... 1... switching power off, removing battery and the after reconnecting battery power on + pressing the reset button on camera. This process done a couple of times.
2.. cleaner tape then loaded successfully.... ran this for a minute. 3.. camera now loading tapes as required.
Jun 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Error message ''condensation operation failed''
1. There is a silver condensation detector in the tape compartment, rear left corner. You can try cleaning this with isopropyl alcohol. I have tried this, and it did not resolve the problem.
2. You can open the camera and unplug the power connector. This will reset the camera, and will resolve the issue for several months. I suggest looking further on this site, where there are instructions for which screws to remove to do this. I have done this, and it has resolved the issued for varying lenghts of time on my GR D30U.
Feb 27, 2009 | JVC Video Cameras
CONDENSATION
Condensation message comes when video head drum got moisture and such moisture can damage tape and video heads. So camera stops function of tape loading and play/ rew/ ff.
Eject and take out tape, if any in camera and blow hot air by hair dryer for 1-2 minutes from at least 6"distance in tape mechanism.
This will evaporate any moisture on video head drum.
and if camera still gives error then dew sensor in camera is bad and you need tech person to replace it.
Dec 16, 2008 | JVC GR-D33US Camcorder
Sony Handycam DCR-TRV22 camera
HI! THE ERROR CODE C:32:10 IS A TAPE LOADING ERROR. IS A TAPE STUCK IN THE CAMERA? IF IT IS OR NOT FOLLOW THE FOLLOWING INSTRUCTIONS TO CLEAR THE CODE!
1.UNPLUG THE AC CORD FROM CAMERA.
2.REMOVE FAT BATTERY.
3. REMOVE SLIM BATTERY, FROM UNDER THE LCD-ABOUT THE SIZE OF NICKEL.
4. WAIT 2 MINUTES.
5.PLUG THE AC TO THE CAMERA.
6. FLIP THE CAMERA TO THE VTR MODE.
7. TAPE SHOULD EJECT AND THE CODE SHOULD CLEAR.
OK? HOPE THIS SOLVES YOUR PROBLEM. DON'T KNOW IF THIS WAS ALL OF YOUR PROBLEM, BUT IT SHOULD SOLVE THE ERROR. IF YOU NEED HELP REPLY TO:
ARCLIGHT1217
Nov 06, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
Receiving error C:31:42. Removed tape, battery, and left opened, but still get error
How long did you leave it to dry? I had a similar problem and had to leave out my camera for more than a day before the problem was resolved.
Jun 19, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Canon ZR700 Mini DV Digital Camcorder Logo
27 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
