Question about Linksys EtherFast EZXS55W 5x10/100 Mbps Networking Switch
Can I connect this switch to a DSL modem and then connect two computers to the switch?
  • 32 Answers
I DON'T BELIEVE IT'S POSSIBLE YOU NEED A ROUTER.WIRELESS N WOULD WORK GREAT.I KNOW THIS BECAUSE I HAD THE SAME PROBLEM.I ENDED UP GETTING A LINKSYS ROUTER.HOPE THIS HELPS.
Posted on Feb 19, 2012
Testimonial: "I thought so. I can hook up the switch to the DSL modem and plug in EITHER computer and they work fine. When I plug in BOTH computers, neither one works. Thanks for the help."
I AM UNABLE TO CONNECT A DSL MODEM AND ROUTER THROUGH SWITCH. AT A TIME I AM ABLE WORK ONLY INTERNET OR LOCAL NETWORK??? PLZ GIVE SOLUTION
Set the modem back to how it was to start with. Plug it into a computer and make sure it is working.
Plug the modem into the routed port on the router. This is labelled ADSL on the one I have here, yours may be different - regardless it's the one that goes to the outside world.
Set the router to factory and plug the LAN side into the switch. Let the router handle DHCP for the LAN and the modem provide DHCP for the router. This results in two layers on NAT, but it's easier than figuring out how to put your modem into bridge mode.
Apr 02, 2012 | Computers & Internet
Trying to access DSL with HP modem
If you mean you're trying to use DSL service with the modem that came built into an HP computer, you can't. That modem is for dial-up Internet service only, or if you want to use your computer as a fax machine along with a scanner or all-in-one printer.
To connect to DSL, you'll need a DSL modem. If you're just getting service, your service provider should have supplied one. (Actually, I think you have the option now of ordering DSL service and not getting a modem if you already have one. Maybe you did this.) The DSL modem has a telephone-type jack to connect to the phone line (same as on the HP modem), but the connection to your computer is through a different, larger, jack usually labeled "Ethernet" or "Computer". If you don't have a modem, you can easily find them for sale. You can buy new ones at retailers who sell computers, and many used ones are available on eBay or on your local Craig's list.
Another possibility is that you already have a DSL modem and are asking how to connect an addtional computer. If this is so, you don't connect the new computer to the DSL phone line. Instead, you need to share the network connection coming from the modem. This is done using a router, which allows several computers to use the same connection either through a cable or wirelessly. The DSL modems typically supplied now have the router built in, with 4 connections for wired computers and wireless capability as well. If your modem is an older one intended for a single connection only, it will have just one network connection. If this is the case for you, you'll need to supply your own router.
Apr 26, 2011 | Computers & Internet
D-Link DSL-2640-T. After power outage, I have a good wireless connection BUT no internet access. LAN line does not work either. Please suggest possible solutions.
chack your DSL settings may your not conacted with your sevice provider
chack your locale settings in modem try folowing setups
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless
Apr 22, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
I'm having problems tring to connect to ATT HS DSL, flashing green light but can not connect to internet, what settings on DSL-2640B do I need???
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Current modem working fine with ATT DSL. I want to install a second modem (2wire) by direct connection to same DSL phone connection (in different room). I have hooked up other modem, filled in user ID and...
Is that second location also a DSL line? You may have to consult with AT&T to see if the DSL line runs to that second location.
What are you trying to accomplish? By adding a second modem, you essentially create two separate networks. Why not use a switch and connect it to the first modem, which would allow you to connect more PCs.
Apr 16, 2009 | 2wire (1000-000057-000) Modem
Trying to connect 4 dsl routers to 48 port switch
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Feb 24, 2009 | 3Com 2250 Plus (3C16476CS) 48-Port...
Linksys EtherFast EZXS55W 5x10/100 Mbps Networking Switch Logo
208 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
