Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
1998 jeep cherokee lift gate will not stay up
2010 jeep Cherokee lift gate lights stay on inside car
grand cherokee.
if outside USA names change. so...
2010 GC. USA,
dome lights stuck on, caused by, door switches stuck on.
cause:
  1. switch bad
  2. adjusted wrong
  3. jammed up.
  4. wires shorted to the switch.
Feb 28, 2015 | 2010 Jeep Grand Cherokee
Lift gate open warning light sounds when temp is below 60
sounds like the cold temps cause the metal door to warp which causes an increased distance to the sensor that tells the computer the lift gate is open. The lift gate sensors should be adjusted to be closer together.
Dec 12, 2013 | 2008 Jeep Grand Cherokee
Interior lights stay on while driving, lift gate sensor flashing and occasinally alarm goes off in middle of night
the switch on the liftgate lock assy is bad. check youtube for a video of it and how to replace it
Nov 12, 2017 | 1998 Jeep Cherokee Grand 2WD
My 1998 jeep grand cherokee is haveing a problem with the security system, I cant seem to get it to reset
Hello
Open the hood,,, disconect both battery cables,, let it sit for 10 minn ,,,,,,conect the battery cables,,,,,,,,,,,,,,,,,, then,,,,,,,,,
Lets try unlocking the lift gate with the key ,,,, move key back and forth 3 times. this should reset the system
Jul 14, 2010 | 1998 Jeep Grand Cherokee
The "Lift Gate Open" Light stays on, on the overhead message panel. The actually lift gate is closed securely.
The lift gate latch is at fault the switch contacts in the latch are worn out replace the liftgate latch and your problem is solved
Aug 29, 2009 | 2002 Jeep Grand Cherokee
1994 Jeep Grand cherokee rear lift gate
Well My 94 Jeep Grand Cherokee had the same problem and we had to just cut into the lift gate panel from the inside. It required cutting plastic but with a 94 looks arent everything and a working lift gate was worth it. But then we pealed back this black plastic mat under the panel and lifted up on the release bar(verticle bar that lifts the latch) and once we got it open we adjusted a little clamp that had slipped. Dont adjust it too much or when u lock it it wont lock! But sorry i dont know the name of the parts. But then u can screw the panel back in and it wont look to bad besides some cuts.
Jun 09, 2009 | 1994 Jeep Grand Cherokee
Lift Gate will not open
Compared with this reference documents: ZJ-Secc-8P-Power-Door-Locks
Good luck... and rated my help!!!
May 05, 2009 | 1995 Jeep Grand Cherokee
Display console
There is a switch in the lift gate latch that closes when the gate is closed and turns off the light, this switch is defective, replace it and the light will go off.
Sep 16, 2008 | 2004 Jeep Grand Cherokee
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
53 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
