Walker tv/dvd combi 22
Dvd playing in black+white,lost color
snakehead
  • 1074 Answers
SOURCE: quasar tv/vcr combo vv2009
clean the head of your vcr if that does not work then you will have to call in the tech to look into your problems goood luck.it is probably the color circuit
Posted on Apr 28, 2007
siphilips
  • 34 Answers
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Posted on Nov 05, 2007
SOURCE: BUSH TV/DVD combi
connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
SOURCE: DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Posted on Jan 08, 2008
SOURCE: tv/dvd combo only plays dvd's in black and white
We had the same problem, the dvd's would play black and white, it took us about 2 months to figure out my son had changed something in the settings, I don't remember exactly what he did but it was something in the menu settings, if your screensaver is in color it's probably the same issue we had.
Posted on Nov 02, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Alba tv dvd combi problem
Picture noise / distortion
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
  3. Try a direct connection from the DVD player to the TV set, instead of via other components.
    Test the wires connector terminal from dirty and corrosion, clean it with contacts cleaner very well and try again.Use the Disk cleaner for clean the Pickup system
    God bless you
Feb 09, 2013 | Televison & Video
Alba led16911dvd
my dvd combi works fine but only plays the dvds in black and white and the dvd part of the remote doesnt work
Jan 19, 2012 | Albatron Televison & Video
My dvd player is playing in only black and white. I cannot figure out how to get it to play in color
I have the same problem.My dvd plays in Black And White.I found out A bulb in the tv burned out.The tv will still play color,but any dvd player will play in Black and White.The bulb is $130.00 to 230.00.Hope you have a warrenty like i doo.Thanks Hope ive helped.John from Riverside RI.
Nov 16, 2009 | Panasonic DVD-S35 DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Jun 17, 2006 | Sony DVP-NS700P DVD Player
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
