Question about Panasonic Heating & Cooling
CS-MC90KE How to remove front grill of indoor unit?
2 Suggested Answers
  • 10 Answers
SOURCE: How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Posted on Jul 15, 2010
How do I remove the Main PCB from an LG ArtCool C12AWR or disconnect air sensor of indoor unit ?
Disassembly - Indoor Unit
Disconnect the unit from power supply before making any checks.
Be sure the power switch is set to "OFF".
To remove the Grille from the Chassis.
• Set the up-and-down air discharge louver to open
position (horizontally) by finger pressure.
• Remove the securing screws.
• To remove the Grille, pull the lower left and right
side of the grille toward you (slightly tilted) and lift it
straight upward.
1. Before removing the control box, be sure to
take out the wire screwed at the other end.
2. To remove the Control Box.
• Remove securing screws.
• Pull the control box out from the chassis
carefully.
3. To remove the Discharge Grille.
• Unhook the discharge grille and pull the
discharge grille out from the chassis carefully.
4. To remove the Evaporator.
• Remove 3 screws securing the evaporator(at the
left 2EA in the Eva Holder, at the right 1EA).
• When repair, do not damage the Caution label.
• Unhook the tab on the right inside of the chassis
at the same time, slightly pull the evaporator
toward you until the tab is clear of the slot.
5. To remove the Motor Cover
• Remove 2 securing screw.
• Pull the motor cover out from the chassis
carefully.
6. To remove the Cross-Flow Fan
• Loosen the screw securing the cross-flow fan to
the fan motor (do not remove).
• Lift up the right side of the cross-flow fan and the
fan motor, separate the fan motor from the
cross-flow fan.
Sep 07, 2015 | LG Art Cool LA121HNP Split System Air...
Does not heat not used but a couple times kind of dissappointed with it
These units get killed when cleaning. Next one get the removable grills. This is an excellent design grill, except the ones with non removable grills- due to short life.
Jun 05, 2011 | George Foreman GR15 Indoor Grill
My george Foreman grill will not heat up.. it worked yesterday.... the timer works fine... can this be fixed?
Unit costs too little to be repaired. Be sure to buy one with removable grills, they last tons longer.
Sep 27, 2010 | George Foreman GFG21 Indoor Grill
Where is the filter located?
Hi, if this is a central system that is split up with the condenser outdoors and the air handler indoors it can be in the indoor unit it self or also it may be in the ceiling or wall near the unit behind a grill for the return air to flow back. Walk around and look for this grill. It is either up high near the air handler close to it, or low on a wall near it. If not out in the home, you will find it in the indoor unit only, nothing outdoors. If you remove a panel you should find it. Please keep me posted and please don't forget to rate me as I no you will be kind. I will check in on you a little later to see if you have found it.
Shastalaker7
A/C, Heating Contractor
Aug 28, 2010 | Goodman Heating & Cooling
Grill build-up
The plates are not removable by the consumer. GF recommends the use of a nylon scrubbing pad and hot soapy water to remove food build up. (Clean after each use).
Dec 31, 2017 | George Foreman GR30 Indoor Grill
grille is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Indoor Grill with removal plates Geo Foreman Grill
I can't find info on the "George Foreman" grill , model : GRP90WGWCAN
It is offered in the prime booklet of our credit card bank.
Dec 08, 2007 | George Foreman GRP4P Indoor Grill
Indoor Grilling vs. Outdoor Grilling.
Basically, if you can grill it outdoor - you can grill it indoors. Notice that indoor grills can't drain liquids as well as outdoor grills, so this should be kept in mind. Bon apetite!
Aug 01, 2007 | Toastmaster TG21W Indoor Grill
Heating & Cooling Logo
60 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
