Question about Kenmore 59940 Kitchen Hood
How to get to filters
Please could someone assist me by letting me know how I access the filters and remove them for cleaning
    Problem Solver:
  • 11 Answers
Try RangeHoodsFilter.com
they mfg filters.
Good Luck
Posted on Mar 14, 2010
Need to clean filter
Hazel, I assume you want to know how to find and remove the filter for cleaning.
The filter is located behind the front air intake louvers and depending on which model you have, the filter can be accessed one of two ways. Before you attempt to remove the filter turn the unit OFF and unplug it.
1. Remove the bucket from it's holder. Look up inside the bucket cavity, just inside the unit behind the louvers and you will see a tab type pull handle. This is the handle to the frame of the filter. Pull it down and out.
2. As you're facing the unit on the fight side just behind the louvers, there will appear to be a trap type door. Open this door and you will have access to pull the filter out.
You can clean the filter in one of two ways: Vacuum it or it it's really dirty, wash it in warm soapy (dish washing liquid), rinse and dry thoroughly. NEVER operate the dehumidifier without the filter in place. Doing so, can cause damage to the unit.
Hope this helped you. Please let me know.
Jul 05, 2011 | Haier Dehumidifiers
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
Where are the cabin filters located in an 2001 Oldsmobile Silhoueete Premiere?
Open the instrument panel compartment door on the passenger side. Remove the rear inside compartment door. Open the access door and you will see one filter, pull it out and the second one is further in next to where the first one was. Reverse for install.
Please let me know if I may further assist you.
Regards, TXTEXAN
Mar 15, 2011 | 2001 Oldsmobile Silhouette
How to change the cabin filter
It's located behind your glove box. Remove the glove box, and you will see a slim verticle access panel to your filter. Remove the access panel and pull the filter out. Reverse for installation.
Please let me know if I may further assist you. -TXTEXAN
Feb 15, 2011 | 2002 Hyundai Accent
Change cabin air filter 2080 Subaru outback
Your cabin filter is hiding above/behind your glove box. In order to access the cabin filter, first remove the passenger instrument panel side cover. Next, open your glove box and there should be one clip on the left and right side of the glove box... remove those clips as well as the tether that is holding the glove box up. After the glove box falls forward, remove the upper storage box. You should now see the cabin filter access panel, which is held in with 5 or 6 screws. Remove the screws, pull the access panel out, and you should see the cabin filter. Reverse instructions for installation.
Nov 22, 2010 | 2008 Subaru Outback
How do you change the cabin filter on a 2001 Subaru outback? Removed glove box but don't see how to find it. Thanks Doug
Once your glove box is removed and out of the vehicle, you will see the HVAC casing. The access panel held in with 4 clips is what your cabin filter hides behind.
Mar 14, 2010 | 2001 Subaru Outback
Where is the battery
hi from what i can remember you need to remove the air filter housing to gain access to the battery and it also made it easier removing the passenger side wheel and inner plastic wing but just removing the air filter housng should give you access to the battery.
Let me know how you get on or if you need further assistance ok
Dec 14, 2009 | 2004 Dodge Intrepid
How to remove front panel to get to filter
The following link explains how to access the drain pump filter and clean:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you have any questions about this procedure, or if you require additional assistance, please let me know. I hope you find this information helpful.
Aug 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing f 2
The F2 code indicates the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 14, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Front loader washing machine is not draining
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Be prepared to catch lots of water. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Regards,
reg501
Jun 29, 2008 | Whirlpool Washing Machines
Kenmore 59940 Kitchen Hood Logo
207 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
