Price for p-3c-1 athena subwoofer - Audio Players & Recorders
My speakers stopped working simultaneously
Power amplifier section circuit in the amp fault. Check and replace damaged component/s at this section circuit. Contact any service technician. This is a skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 05, 2015 | Athena WS-60 Wall-Mountable 3-Way...
Fuse keeps blowing up as power is turned on..help.
Greg, If the fuse keeps on blowing there is a problem with the internal amp. It was probaly caused buy a electrical power surge, Or a (********) up Sub patch cord,
Oct 04, 2012 | Athena AS-P4000 Subwoofer
AS P4100 sub. Fuse is blown. Will replacing it fix the problem. Other owners have replaced the fuse without success
yes unless the cicurle board has something cross and is bowning your fuse.Check your manual and read on there for local your fuse and what to do.If that dose not work.Call the place where you go it from and ask them what to do.
Mar 15, 2011 | Athena AS-P4000 Subwoofer
I also have an Athena ASP4100 sub woofer which blew the fuse on the circuit board and when I replaced the fuse, it just blew it again. As an electrician, my understanding would be the circuit board has a...
You should look at the circuit board for the power amplifier and check for any leaking or bulged electrolytic capacitors. If this speaker uses the circuit boards made by AMI (such as most JBL and Mission sub woofers around 1999-2001 vintage) they had a lot of problems with this as well as bad modules. Google for the module S53AMI and you will find lots of info if this is what you have in that Athena.
Feb 21, 2011 | Athena AS-P4000 Subwoofer
I have a pair of athena p3c1 subwoofers. the problem i have is that no sound is comeing from them but the power light is on. they both stopped working at the same time. i have had the subs out to check for...
Don't understand why 2 subwoofers?
As a tech my attention is drawn to what you said-they both stopped at the same time,have you checked the signal from the source--ie- disk player ,tv,etc
Try plugging something else into the subs separately
if still no go have you got access to the speaker cones?
if yes then place your ear close to the cone and move the cone down and up evenly with your fingers
If you hear a rasping sound the voice coils are blown
if all is clear check the speaker fuses on the amplifier boards
If you have a multimeter set it to low ohms,the reading should be 4 or 8 ohms .you can check this on the speaker label
make sure you disconnect one speaker terminal before testing or the amp output capacitor will affect the reading
Hope this helps
Len
Oct 20, 2017 | Athena P3 Speaker
What is a good price for two kicker comp vr dual voice coils?? How many watt does each one have??
2 10" Kicker Comp VR's will run you about $150.00 each new from most dealers a good price for 1 10" should be anywhere from $130 - 160 no more and never less.
$160 -$190 for 1 12 " CompVr
Jun 17, 2010 | Kicker Comp VR Car Subwoofer
Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Mar 09, 2010 | Athena AS-P4000 Subwoofer
How can I mount these on the wall?
The WS-100 is a floor standing speaker, and they are equipped with polycarbonate bases, attached right out of the box for ease of setup, providing a secure stable speaker system.For the price you paid I would not risk wall mount but if they must be eleveate I suggust a mounting shelve then the speakers ontop (shelves must hold speaker weight)
Oct 05, 2009 | Athena WS-100 Speaker
Need instructions for Toastess cinema popper TCP-6L
1 tbsp veggie oil for 1/3c. corn
2 tbsp oil for 2/3c corn
3 tbsp oil for 1 cup corn
i use 2/3 c as the max because it completely fills the bowl if you use 1 cup be sure to do it in batches or the machine will over flow.
happy popping
Aug 30, 2008 | Toastess TCP-6L Popcorn Maker
 Grubhead
Grubhead
