Question about Panasonic NV-DS65 Mini DV Digital Camcorder
Camcorder won't record or playback
My Panasonic camcorder won't record anymore. I thought it was the battery - so I replaced it. When I turn it on, the power light blinks 2 times, pauses, blinks 2 times, etc - then eventually shuts off. No buttons work at all - can't record, playback, take pictures, etc. I can't find anything in the troubleshooter section of the manual. Is it worth it to have it fixed? Hoping it is something simple.....
  • 66 Answers
The problem above fix it for me. it was a ribbon that had come out just a little bit the cam works well now. the problem for me got worse over time till it nolonger did anything. so thank medusa.
Posted on Dec 26, 2007
Panasonic NV-DS65 Ok, here goes, I had the exact same problem on my Panasonic NV-DS65. I've finally figured it out, I hope it helps on your cameras. Remove the bottom plate from the Camera (8 screws, 5 on the bottom plate, 2 on the side beside the hand grip(you will need to remove the grip), open the LCD screen and locate 1 screw below the ?still p-in-p button?. Then pop off the bottom plate of the camera Look at the ribbon cables carefully and gently push them all snugly into the plugs in case they are loose. The tape transport mechanism may have moved them out of place. Replace the cover and that?s it. Use a small screwdriver (one for repairing glasses is ideal) and do it over a table to prevent losing the screws. Also there are 2 sizes of screws so make sure you know what goes where. Thats it, hope it helps
Posted on Jan 19, 2007
I have the same problem It seems it is a tape drive problem I just wanted to say Lots of owners are having the same problem more over the the 3V battery shows empty on power on while it is not empty taking the tape out allows you to play with menu and view the image * you can also connect to the pc via Firewire connection and record in the PC hard disk or even change the line input from the menu to AV in and use the Camera as a Analouge to DV Vedio converter This goes to show that the Camera is woking fine , untill it is asked to move the tape * The only way to stop the camera from turning off is 1) take out the tape 2) in play back , press play the pause (some poeple claim to have solved the problem that way - has not worked for me )
Posted on Sep 18, 2006
Panasonic camcorder playback and recording problem
We need more details on the problem,
Does the camcorder stay on, or it switches off , when the recording stops ?
Aug 30, 2008 | Panasonic NV-DS65 Mini DV Digital...
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Camcorder won't record or playback,has distortion and low volume.Is it just real dirty?
Try to find a video cam ,,head cleaner,,at elonric s store ,,find online,,,try cleaning the heads down in there with alcohol and a q tip,,,also,,good luck,,but thats what it is just dirty,,
Dec 23, 2011 | Quasar VM-L152 Camcorder
Operation problems with Panasonic HDC-SD5 camcorder
it's not very clear if it is a software malfunction or hardware,so i recommend to you to visit local service center.In my opinion this is hardware problem in rear operation unit .
Jul 27, 2009 | Panasonic HDC-SD5 Flash Media Camcorder
Camcorder is dead - power supply not to blame.
Intermittent fault? Playback of recorded footage not possible.
Even tried to check 'playback' with an older tape.
Jun 23, 2008 | Panasonic NV-MX350B Mini DV Digital...
Panasonic NV-DS65 Mini DV Digital Camcorder Logo
244 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
