Question about HP Compaq nc6320 Notebook
Power on password
When i power on my compaq laptop the first thing it will display is compaq then after that it will display enter power on password. but i dint know the power on password.pls i need help urgently.Pls reply via my email adress.[am_x84@yahoo.com].Thanks
  • vincent1leo Dec 01, 2008
    when i switch on my laptop (compaq n*6110 ) it asks for a power on password. I am not able to sort out the problem.I dont know the password and also no key is working to type a password. How could i solve this?
    what are the different alternatives for this?
    Please mail me the information to mail Id vincent1leo@gmail.com
Power-on Password
b> If your HP Compaq 6715B laptop is lost or stolen, the power-on password can protect the valuable data on your computer. Even so, there may be times you'll want to clear that password and knowing the right procedure will make that easier. Once the power-on password is cleared, the Compaq 6715B will no longer require you to enter a password just to start up your laptop.
Shut down your Compaq 6715B and wait for it to power off. Press the "Power" button to restart the laptop. Tap the "F10" key after the Compaq splash screen appears. Wait for the setup menu to appear. Use the arrow keys to navigate to the "Security" menu and scroll down to the "Power On Password" option. Delete the entries in both boxes, then press the "F10" key. Choose the "Save Changes and Exit" option to exit the setup menu. Wait for the laptop to restart and verify that the laptop does not prompt for a power-on password. Hope this helps.
Dec 15, 2012 | HP Compaq 6715b Notebook
Disabling power on password for cq10-405dx
You have to enter to the BIOS and turn it off. But you have to know the password.
Dec 06, 2012 | Compaq Mini Netbook Cq10405dx Intel AtomTM...
How to disable drivelock password
The Compaq drivelock feature is designed to protect the data on a laptop's hard drive by assigning a password.
This password protects the drive in the event the laptop is lost or stolen, but can be removed when necessary.
Knowing how to remove or change the drivelock feature can make your Compaq more useful and more secure.
Power on your laptop and enter the drivelock password you established when you turned the drive protection feature on.
You will need this password to access the drive and turn off the drivelock feature.
Click the "Disabled" option in the drivelock menu.
This will turn off the drivelock feature on the Compaq laptop.
Do not enter anything in the password blocks.
Log on to the laptop, click the "Start" button and choose "Shut down." Choose "Restart" from the menu to power cycle your laptop and verify the drivelock setting is off.
If the drivelock setting is off you will not be prompted for a password when the laptop starts up.
hope this helps
Oct 19, 2012 | Compaq Presario 2140US Notebook
How to clear bios password in Compaq 8510P Thanks
hello sir ... enter 3 time wrong password then u will see a code like this CNU1234ABC send me code ill wil send u master password Thanks
Oct 27, 2010 | HP Compaq 8510p Notebook
How do I reset the power on password on my Compaq presario C300?
1.Reinstall the whole thing...
2. Enter the Bios and attempt to reset. (Unlikely)
Jan 13, 2010 | Compaq Presario Notebook
Hp presario :the screen displays only ''enter password''
press f2 or equivelent to enter bios on start up at end of top bar turn off all passwords then hit f10 save and quit restart laptop and see if this works
Jan 01, 2010 | HP Compaq Presario V3000T Notebook
Power-on password forgotten! How can the computer be started?
The Power on Password is set from the BIOS configuration. Ask that person who borrowed your Compaq for the password. Once you have this password, you can enter the BIOS configuration and remove/disable this password.
Depending how old you Compaq is, removing the BIOS battery and main battery for 15+ mins may remove this password and restore the BIOS to the factory default (insert both batteries again) and configure the BIOS Date and Time etc.
BUT if the the password is stored on an EEPROM chip then removing will not fix this problem. There are no backdoor passwords available.
Nov 19, 2009 | HP Compaq nx6110 PC Laptop
I turn on my compaq presario c300 and it immediately take me to an enter power-on password screen
A password on boot is not set by default. The owner activates this option. If some prankster or michief maker has entered a password on boot on your computer without your knowing it, there is nothing you can do, save taking the machine to an HP Certified Service Center to have the password removed or reset.
As the password on boot is a deterrent against computer thefts, you might be asked to show proof of ownership. This certainly is the case with Toshiba laptops.
Hope it helps.
Aug 30, 2009 | HP 435768-001 - Compaq Presario C300...
Power on password problem
there are several ways on which you can reset the cmos in your pc, most common ways are removing the battery (like what you did) or doing a short circuit on the battery or reset pins. However there are some manufacturers now that use a different method, I had a dell PC before where the reset pins are already shorted, to reset it, I had to remove the jumper, power the device for 10sec, power it off then put the jumper back, kinda odd but I guess that how dell wants it, you can try that method as well. there are some that requires a key or before it could be reset like what I heard on some HP brand computers, the use has to call HP, then they ask for the serial or something then give ot generate a key. The best advise is to consult the documentation or vendor of your laptop for details on how to get your reset your laptop.
cheers,
Aug 20, 2008 | Compaq Evo N610C Notebook
Compaq armada 4131T
hi,i presume that u cannot punch in the password as the keyboard is not working, except the Enter key, u can do two things, reset the bios, or repair the keyboard, by removing it and cleaning the contacts, to reset the BIOS, locate the small lethium battery, remove it and keep it outside for some time, then put it back,that will reset the BIOS.. try either of it.. let me know...
Dec 04, 2007 | Compaq Armada 4131T Notebook
HP Compaq nc6320 Notebook Logo
170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
