Question about Transmission & Drivetrain for Daihatsu Charade
HOW HOW TO TOP UP AUTOMATIC TRANSMISSION FLUID IN 1990 DIHATSU CHARADE SU
FOUND THE DIP STICK BUT I CANT FIND WHERE TO ADD THE QUARTER LITRE OF TRANSMISSION FLUID
  • vass Feb 19, 2012
    Do i just use the dip-stick tube and carefully pour it down that a little at a time ?
AutoDoc
  • 169 Answers
SOURCE: torque settings
Is the engine size 1.0L or 1.3L?
Posted on Aug 31, 2008
AutoDoc
  • 169 Answers
SOURCE: dihatsu charade torque settings
Peter Watson, what engine size do you have?
mx5turbo92
  • 545 Answers
SOURCE: what should the valve timing be on a 1990 daihatsu charade 1990 3 cylinder
Ignition timing should be checked and adjusted whenever spark plugs are replaced or any distributor maintenance is performed. Ignition timing at 1000 RPM or less should be as follows: on 1989 1.3L/4-79 engines, 3-7°BTDC; on 1990-92 1.3L/4-79 engines, 0-2°; on 1.6L/4-97 engines, 1-5°.
Posted on Jun 03, 2009
mythman
  • 84 Answers
SOURCE: i have a 1988 dihatsu charade that keeps over
Engine overheating can be caused by one or more of these reasons: 1) Little or no coolant/liquid in the engine cooling system, 2) faulty connections of hoses, 3) failure of auxilliary fan to operate (for FWD vehicles; temp sensor failure also) 4) cracks or leaks in the engine cooling system, and 5) failure of the water pump assembly.
Have these thoroughly checked out to find the cause of your problem. If all factors point to a sealed and working system, there might be a clog somewhere that prevents efficient operation at higher speeds.
Hope this helps.
Posted on Jul 01, 2009
  • 275 Answers
SOURCE: my dihatsu charade stops running and lets off a
Sounds like its the catalytic converter/exhaust silencer thats blocked. That will stop the engine running and give a nasty smell. You should get the car to an exhaust specialist that can test and replace , if necessary , the exhaust. He should be able to test the oxygen sensors too. Hope that helps
Posted on Feb 10, 2010
Testimonial: "cheers for that it makes sence "
2009 Hyundai Sonata automatic transmission fluid changing, How to fill the tranmission, is there a fill plug? OR should i use the
You add fluid in the same pipe the dip stick is in. Remove the dip stick and insert a funnel and add fluid through there. Check it frequently since there is no way to remove fluid easily if you over fill the transmission.
Jun 06, 2011 | Hyundai Sonata Cars & Trucks
Can't find the transmission fluid fill on 1990 F150.
right side of engine near firewall (if it is a automatic)
Jan 06, 2011 | 1990 Ford F150
Were is the trasmission fluid ..anything on this engin? cant find the dip stick or were to add fluid.
If it's a stander transmission you add under your truck on the side of the transmission where it reads fill, if it's automatic it's has to have and dip stick for that year truck.could be missing check the side of transmission above transmission pan toward the front for a hole where the tube goes in, it would also be leaking if gone.
Jun 29, 2010 | 1988 Ford F 150
Can ODB2 READERS READ THE TRANSMISSION TEMP ON THE
code readers cant.the scan tools can but are real expensive.if you havent drained the trans oil yet just drive it around a while and check it.if you have drained the oil then try to measure what you took out and put that much in.if you cant measure old oil then add fluid while engine running in nuetral{double check the nuetral position writen on dip stick} add fluid untill oil is below the add level let it run for a while say 30 minutes and recheck add th full then go drive it around.recheck again if low add if high drain out or siphion some out throuh small hose through the dip stick tube
Mar 19, 2010 | 2007 Jeep Grand Cherokee Overland
I have a leak in my 97 automatic subaru legacy and need to add some fluid to my transmission just to get it to a shop. It doesn't say in the manual or on any site I've been to where to add it or what kind...
The type best used is "Genuine Subaru Automatic Transmission Fluid Type-HP or IDEMITSU ATF HP. you add it through the dip stick hole. You may also wish to add a transmission leak oil to swell the gaskets and stop the leak add it the same way if you choose to use it. both of these should be available at your local auto parts store like NAPA. Raz,...
Aug 21, 2009 | 1997 Subaru Legacy
Transmission making terrible sound trying to add fluid but can't find where to add fluid on the 85 chev truck
if automatic add after you pull the dip stick, if manual trans, top where the shifter is ,a plug to add fluid, all i no that you since you didnt put automatic or manual trans, thanks hope this helps you, robert b.
Jun 26, 2009 | 2003 Chevrolet Silverado 2500HD
I cannot find where to put the transmission fluid in my 1999 Isuzu Rodeo. There is not an area on top to put more fluid, let alone check the fluid.
I have a 1995 rodeo with an automatic. the fluid level is measured on the dipstick, which is next to the oil dip stick on the v-6 anyway. you add fluid by removing a plug unedr the vehicle mounted up near the center of the transmission.
Jul 31, 2008 | 1995 Isuzu Trooper
GMC Vandura 1983 6.2 litre diesel automatic transmission oil GMC Vandura 1983 6.2 litre diesel automatic
Your dip stick tube is your fill tube for your transmission . Make sure your transmission oil is at opperating temp before servicing some instructions are written on the dip stick , Use a small funnel , Add a little at a time (cup). Use the proper fluid , check regularly
May 18, 2008 | 1989 GMC Dura
Transmission & Drivetrain for Daihatsu Charade Logo
94 people viewed this question
Top Daihatsu Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Daihatsu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
