Unit will not power up
RG-7 graphic equalizer
    Novelist:
  • 170 Answers
Start with the simple fix first. Is the unit powered by a wall transformer or an ac line cord. When I have these problems I always start with the wall converter. Maybe it's dead. Substitute another converter of same or lower voltage. Does the unit power or at least light up? Bingo, Swap converters. Don't assume the converter is working. Ac line cord? Swap it out. Fuse on the unit? Check or replace it Final idiot fix - plug a test light into your ac outlet. Be sure it's live. I spent an hour frantically tracing power trouble on a PA set-up, only to discover ONE outlet in a duplex was bad. Now I check with a power test light first. ***************
Posted on Dec 03, 2008
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
I need help downloading a equalizer for my computer Lenovo think centre/win 7 pro /64 bit can't get anything to work when I try
There are built in equalizers on certain players.
KMPlayer and VLCplayer both have equalizer functions and are free players.
If you use Windows Media player, here is a link to show you how to open and adjust the on board graphic equalizer.
Change bass stereo and other audio effects in Windows Media Player Windows...
Now, if you want a stand alone equalizer you will simply need to Google "Graphic Equalizer program for Win 7" and you will get PLENTY of results of free EQ's. Most of them are rated. I grabbed a couple to play with them, but as of this post, I have not yet.
Jan 08, 2015 | Lenovo Computers & Internet
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I have a Technics Stereo graphic equalizer. Trying to find out why it's not getting any power. it has no fuse inside. I hook the plug into the outlet and nothing. atleast the light on the equalizer does...
The power supply unit has failed in your equaliser. If it is the main transformer check for the continuity of the primary and if open you will need to replace with the same one or rewind with the same parameter.However if the thermal fuse is blown you can short the winding with a fuse wire. Also check on the dc side for any fusible resistors that would have opened out. Hope you check this out. Good day
Aug 03, 2010 | Technics SH-GE90 Home Equalizer
How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
Jul 05, 2009 | Yamaha EQ-70 Home Equalizer
In car graphic equalizer installation
035132ed-916f-4d02-8e5e-9fa428212a36.jpgPyramid stereo graphic equalizer model 9700g - Page 6
Mar 23, 2009 | Pyramid 801 10-Band Car Equalizer
Pioneer spec 1 and spec 2 hook up with RG 2 processor and audiosource eq 1
preamp out---------to equalizer in-------------equalizer out----to amplifier in-----------amplifier out----------to loudspeakers.
Jun 12, 2008 | Pioneer Audio Players & Recorders
251 people viewed this question
 Grubhead
Grubhead
