Question about LG Washing Machines
Lg wd-8013c washing machine all lights flash and beeps but wond wash?
Wd-8013C model
4 Suggested Answers
  • 63 Answers
SOURCE: need diagram of installation of door handle
www.apwagner.com. You will need the model number. The diagram will give you a general idea of the assembly, but no directions. Good luck.
Posted on Sep 28, 2009
  • 6277 Answers
SOURCE: I need an instruction manual
Sorry but this forum does not supply any type of manual direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 16, 2011
ginko
  • 19396 Answers
SOURCE: clues to the proceedure in
Hi.
LG front loading washing machines can be direct drive or belt drive. The 8013C should be belt driven.
In the belt drive models:
  • Remove the back cover.
  • Take off the belt turning the pulley.
  • Unscrew the bolt to pull out the pulley
  • Access the drum bearing behind the pulley.
Here exploded view of LG belt model, click on the picture to enlarge:
Note: with LG direct drive machines the procedure is similar, only you pull out the rotor instead of undoing belt and pulley.
Regards.
Ginko
Posted on Jun 04, 2011
Temp lights flashing LG intellowasher WD 80100tp
it appears the diagnostic computer has found a problem with the water inlet servos and may need replacing contact LG for replacement parts
Jul 29, 2016 | LG Washing Machines
Lg intellowasher 7kg wd 8013c
the push to on switch may be not in operation pl.. check
Oct 01, 2017 | Washing Machines
LG Intellowasher 7 kg WD-8013C power off (short circuit). When I turn on my washing machine, after 5 minutes, it power off. I have a short circuit somewhere, when started to load the water. Also I don't...
Hi Scutrera, You stated that when the machine fills with water that the unit switches off? sound like there could be a problem with the heating element. It may be that there is a hair line crack somewhere on the element causing the water to seep throught and make contact with phase which in turn trips the main RCD. Your best bet is to call up a local Appliance Service Technician to run a (PAT) test to determine if there is an Insulation breakdown with the internal circuit of the machine. I would strongly suggest getting profesional help when assisting in this matter as there could be fatal consequence if safety procedures and requirements arn't met, hope this helps.
May 01, 2011 | LG Washing Machines
I need an instruction manual for LG Intello Wash 7kg WD 8013C
Good luck,
John C
Mar 16, 2011 | LG Washing Machines
Need diagram of installation of door handle WD-8013C washing machine, have new part but cant fit please help
Sep 28, 2009 | LG Washing Machines
Lg wd-8013c washer door latch broken. Is there an emergency release?
Run a shoelace between the door and the face of the washing machine, starting at the top, over the latch on the middle of the right hand side and down to the bottom.
Pull both ends of the shoelace towards the hinge on the left.
This pulls open the latch with NO DAMAGE and allows access to the screws that remove the latch mechanism. Easily ordered and installed with two screws and a plug to reattach.
LG give no support or reference to this easy procedure in their manual. SHAME!
Sep 14, 2009 | LG Washing Machines
Cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Apr 25, 2009 | LG Washing Machines
Lg washer model no wd 8013c door wont open tried everything and the child lock is disengaged
How to get the door open:
Thread a shoelace between the door and the front of the machine from the top, over the latch on the middle right and to the bottom. Pull both ends of the shoelace towards the hinge on the left and this will manually pull open the latch with NO DAMAGE. Once open you can access the screws to remove the mechanism and simply buy a replacement.
LG, bloody hopeless support and no simple way to rectify this problem in the manual when it's so easy once you know.
Jun 19, 2008 | LG Washing Machines
Washing Machines Logo
500 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
