Question about NEC MultiSync VT540 Multimedia Projector
Red and Orange Lights are on, and wont power up. Just changed the lamp
2 Suggested Answers
SOURCE: LAMP not switching on NEC HT410
I had the exact same problem and solved it. After calling NEC tech and getting no help, my son and I decided to:
  • Remove, clean and reset lamp.
  • Completely clean (with compressed air) system.
And it worked. Here's what we did.
  • Removed lamp and cleaned with compressed air (in cans).
  • Used two cans of air to completely remove all internal dust. In our case long over due.
  • Reinstalled lamp and reset meter. (To reset: Turn on machine, wait 2 minutes or so, then hold down the "Help" button right next to the infrared sensor on the front of the machine).
Works fine now! Dont know if it was technical solution but solved it for us! Good Luck!
Posted on May 18, 2009
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
EPSON ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
Mar 26, 2010 | Epson Replacement Lamp Projector Lamp For...
Lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
'86 Mustang Head Light Switch Pin Out Connectors?
I can give you 94 mustang. Don't have 86 but maybe similar
7fc8945.gif Pin Number Circuit Circuit Function B1 38 (BK/O) Power Supply to Battery B2 195 (T/W) Tail Lamp Switch Feed I 19 (LB/R) Instrument Panel Lamp Feed IGN — Not Used R 14 (BR) Headlamp Switch to Tail Lamp and Side Marker Lamps H 15 (R/Y) Headlamp Dimmer Switch Feed DN — Not Used D1 54 (LG/Y) Interior Lamp Switch Feed D2 706 (GY) Battery Saver Door Switch Feed
Apr 30, 2009 | 1986 Ford Mustang
Nec projector vt440 wont turn on
Hello. First check the lamp! From your description, it sounds like the projector is telling you that the lamp needs to be replaced. In "eco mode", when the power is green and the status is steady orange, that is the error message. In "high brightness mode" the status will be steady red. Hope I helped you.
Feb 22, 2009 | NEC MultiSync VT440 Multimedia Projector
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
NEC MultiSync VT540 Multimedia Projector Logo
29 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
