Question about RCA CC6251 VHS-C Analog Camcorder
Error Code EO4
Powers down when installing tape
What does code eo4 mean?
Depends on make and model possibly year. I just googled
"code eo4" and lots of different appliances use that code. So I recommend you add what it is and the code, you may get an answer and a solution.
Mar 11, 2015 | Heating & Cooling
How do I clear error code eo4 on my casio ce 3700
What were you doing or trying to do when you got this error code?
Apr 09, 2012 | Computers & Internet
What is a eo4
ERROR CODE EO4 SAYS TAKE TAPE OUT AND REINSERT IT BUT TAPE WONT COME
Sep 10, 2009 | JVC GR-D73E Mini DV Digital Camcorder
Heayrt won't fire e4 can't hear fan runnung
I am not sure if you have gotten this issue corrected, or not, but the first thing I would try to do is to reset the heater computer system. This sometimes corrects and EO4 error code.
What you will do is open the right hand side door and find the POWER toggle switch, turn that off. Then find the CIRCUIT BREAKER for the heater and turn that off as well, then wait about 15 to 20 minutes. After waiting, you will turn the CIRCUIT BREAKER on first, then the heater. Try and start the heater up.
If the EO4 code comes back, there may be an issue with the heater. If the code does not come back and the heater starts, then the error code was what I call a "computer hic-cup".
Jul 04, 2009 | Pentair MINIMAX NT TSI IGNITER
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
JVC GR-D33U ERROR CODE EO4
· http://www.camcorderinfo.com/bbs/index.php
· JVC camcorders
· Tap o the side to fix your problems
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
· -I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Feb 11, 2008 | Video Cameras
JVC GR-D30U
Waarschijnlijk staat de kop vast
Oct 31, 2007 | JVC 580136 Camcorder
E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Jun 08, 2007 | JVC Cybercam GR-DVL820 Mini DV Digital...
Eo4 error code
HI SIR the fault is caused either by the take up or supply reel in the camera they are not rotating when the tape is inserted.maybe A defective tape or hung reel brake can cause this issue.or maybe a bad loosen guide of the tape path is lame , Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. thanx and plz try to rate and remember i am here just to help u thx
May 08, 2007 | JVC GR-SXM920 Camcorder
EO4
Something is causing either the take up or supply reel in the camera not to rotate when the tape is inserted. A defective tape or hung reel brake can cause this issue. Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. Good luck my friend, Joe Weibel customelectronics.org
Jan 25, 2007 | JVC GR-FXM270A VHS-C Analog Camcorder
Video Cameras Logo
27 people viewed this question
Top RCA Video Cameras Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
ray gallant
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
