Question about Gateway 600XL Notebook
DVD/CD problems I have a Gateway 6439 laptop. My DVD/CD player reads in use in the properties. No disk are in the system. I believe this problem resulted from stopping a CD while in use. My system has since been slowed and my audio now sounds interupted. Any solutions
3 Suggested Answers
  • 237 Answers
SOURCE: DVD/RW LAPTOP PROBLEM
Uninstall the dvd/rw driver, and reinstall it from the Gateway website. Look for your laptop model there, and they have all the drivers and software for your laptop components.
Posted on Nov 23, 2008
cpenzes
  • 1102 Answers
SOURCE: Gateway 6438
DEVICE MANAGER UNINSTALL THE DRIVE THEN RESTART PC AND REINSTALL
THEN DO A DISK DEFRAG
LET ME KNOW IF THIS SOLVED IF NOT WE CAN TRY ANOTHE SOLUTION AND PLEASE RATE ME
Posted on Feb 08, 2009
9339009664
  • 70 Answers
SOURCE: Gateway Laptop DVD/CD Problem
clean the lence of dvd player or replace with new good one
Posted on Aug 23, 2009
Gateway m-1625 CD/DVD-rom won't read any disc. Its spinning but no read. any thoughts?
you might try taking a q tip and some alcohol and clean the eye ( a little glass looking circle ) that reads the disk. Do not touch it with your fingers. Sometimes dust or dirt can get on it and it will not read the disk. This also works on cd players as well as dvd players.
Aug 30, 2011 | Gateway T-1625 Notebook
Gateway NV53 win 7 64bit //the dvd-super multi dl driver stop read dvd/// cd
Click start control panel system and security system device manager, management, scroll down cd-dvd rom drives you might see a yellow question/exclamation mark ? or a red X right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel system and security scroll to sytem tab you will see device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 24, 2011 | Gateway (5500652) (  5500652)...
DVD-RAW does not read DVD. It is unable to find a DVD. Is it DVD problem or player problem?
I think I've just answered this question :-
It won't be a driver problem, DVD drives are generic, it will be either the drive has a problem, the dvd has a problem or your media player has a problem
1) Drive issue - does it player other dvd's - if yes, your drive is ok, if now you have a drive problem, try using a CD lens cleaner or a blast of canned air to clean the lens.
2) Disk issue, if just one disk doesn't play, then its a disk issue or data issue. Assuming the disk is clean and not scratched. Does the Disk have the correct country coding for your region. If not then you have to change the region setting on your DVD player
RMB My computer - Manage - Device manager - Optical drive - Properties - Regional settings.
Bear in mind most DVD player will only allow about 5 changes.
3) Media player, your current media player may not have the correct codecs to decodes the video files on this disk. Go to filehippo.com download and install VLC media player. This will play about anything and its free.
Nov 27, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My gateway laptop's dvd/cd drive stopped working, all of a sudden, but it plays music cds, it is just the DVDs that don't play them or even explore... what could it be the problem? how do i solve it? it...
Are you sure yours is a DVD player? It could only be a CD-CD writer, which will NOT play DVDs.
Open your control panel ->system->hardware->device manager and click on the DVD/CD-ROM drives icon. The listed devices will tell you if you really have a dvd player or not. If you do really have a dvd player, try a different dvd
Mar 19, 2010 | Gateway MX3228 Notebook
DVD player won't read dvd-r. what can I do?
If you have determined that the problem is not the DVD-R disk (runs in other DVD players), try running a CD/DVD cleaner. If that doesn't solve, it's probably a hardware issue.
Jun 13, 2009 | Gateway (5500652) (  5500652)...
Gateway 6438
Feb 08, 2009 | Gateway 600XL Notebook
Oct 27, 2008 | Gateway MX6438 Notebook
Oct 26, 2008 | Gateway 600XL Notebook
Gateway 600XL Notebook Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
