Question about Radio Communications
Bypass echo board on2527 galaxy still talk - Radio Communications
    Genius:
  • 1,212 Answers
To disable the echo, the simplest method is just cut the jumper wire from the power supply section to the switch.
To bypass a faulty echo board, connect a sheilded jumper from pin of IC1 to the Voice position of the the connector/R63 at J6 . Isolate the echo board completely by removing one side of R39 and R68
Posted on Feb 19, 2012
5 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: How to install echo board in a Galaxy 2547
  • The DX2547 is the same as a Galaxy 959 - a SSB/AM CB radio. The standard of echo boards is the TRB-X2. This installs the same way in most CB radios. I have uploaded an instruction sheet here http://minus.com/lbkZJ6ZfR6qbEY Very easy to follow. If you happen to have any further questions please feel free to ask.
  • Hope this helps..
Posted on Nov 03, 2011
Ironfist109
  • 3018 Answers
  • The DX2547 is the same as a Galaxy 959 - a SSB/AM CB radio. The standard of echo boards is the TRB-X2. This installs the same way in most CB radios. I have uploaded an instruction sheet here http://minus.com/lbkZJ6ZfR6qbEY Very easy to follow. If you happen to have any further questions please feel free to ask..
  • Hope this helps.
Ironfist109
  • 3018 Answers
SOURCE: How to install echo board in a Galaxy 2517
  • This radio already has an echo board installed in it from the factory. On the bottom set of knobs, left side, over three knobs. That knob is your echo/delay knob. No need to install one. Just turn it on.
  • Hope this helps.
Ironfist109
  • 3018 Answers
SOURCE: Install Echo Board in Galaxy 2517
  • Hope this helps..
Why is there an echo when talking on my samsung galaxy s4
There was network problem. Change your simcard.
Jun 12, 2014 | Samsung GALAXY S4
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
  • Hope this helps..
Nov 03, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
  • Hope this helps.
Nov 03, 2011 | Galaxy Radios DX-2517 CB Radio
  • Hope this helps.
  • Hope this helps..
I was wondering if it was possible to install a lt-2d echo board into a galaxy saturn base station to replace the factory echo?where i,m lost at is it says to unhook the audio wire on the mike socket but...
Don't mess around inside a CB unless you are skilled in electronics. Modules in a CB don't switch out like a computer, everything is soldered in. The echo board manufacturer should have a compatibility list at their web site. Factors to consider its size, can it use existing wires, do the voltages match? You might consider contacting tech sellers on ebay selling similar items or similar radios. The easy fix is to buy a mike that also has a built in echo feature.
Feb 27, 2011 | Radio Communications
How do I adjust echo on galaxy saturn base?
Inside of the cabinette there is a small pc board located on the right side of the chasis. It sits vertically and has a metal cover on it. There are 2 potentiometers on the board. One is for depth of echo and the other is for speed)
Mar 07, 2010 | Radio Communications
My 2517 talks good after awhile on it it just drop out like dont have no mod but receive good let it cool it go back workin fine any idea? shows when this happens it shows on radio signal moving none on...
Hi and welcome to FixYa,
On a MOSFET version of a Galaxy DX2517 and assuming stock mic, heat related issues of missing modulation would require initial checks of:
  • echo circuit - board EB-2000 EPT0SSB51J;
  • mic amp - IC7 NJM4558D;
  • AF power amp - Q53 to Q55.
Good luck and thank you for asking FixYa.
Nov 09, 2009 | Galaxy Radios DX-2517 CB Radio
Echo Problems
RF limited TBR-2 turbo echo board. It will plug in to the factory wires with no alterations. It will give you much more control.
Dec 13, 2008 | Galaxy Radios DX-2517 CB Radio
Radio Communications Logo
137 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
