Question about ASUS Computers & Internet
Windows telling me to plug ethernet in
I am unable to connect my new build to the internet. The driver is showing up under Device manager and is enabled in Bios. The ethernet cable I am using is verified good and the lights on the port on the mobo are flashing. The router is verified good and it does not work coming from the modem either. I have tried updating to latest LAN driver also but still nothing. I am using Windows 7 Home 64 bit OEM.
  • Matthew Hall Feb 19, 2012
    Motherboard: Asus Maximus IV Z-Gene/3Gen
    i7 2600k 3.4GZ
    I tried the steps in Control Panel and Device Manager did not work. I tried flashing Bios with newest version from Asus website and nothing. The modem shows the port being used by the PC is communicating and the port's LEDs are blinking and NOTHING!
    Someone please help me!!
  • 32 Answers
On the desktop task bar bottom of screen computer monitor icon.left click one time and window will open click on open network and sharing center.network and sharing center window will open look to the far left for change adapter setting.click on change adapter setting this will open up your local area and wireless connections.right click on local area connection and click on properties local area connection properties window will open make sure the internet protocol 6(tcp/ipv6) is checked as well as the 4tcp/ipv4 click on ok you should be able to go online now.keep in mind that you will need to check your wireless adapter to insure you can connect to internet wirelessly.hope this helped.
Posted on Feb 19, 2012
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Motherboard P4i65GV ASROCK. Installed WIN XP service pack 2 , ethernet controller is not installed shows exclamation mark in device manager.Unable to connect to net.
you must ethernet controller driver first
goto device manager, right click at exclamation mark, then chose update driver, follow instuction step by step, if it ask for cd driver insert motherboard cd driver, if you did not have cd driver download ethernet controller here
http://www.asrock.com/MB/download.asp?Model=P4i65GV&o=XP
wait until process finish and exclamation mark at device manager disappear, and try to connect your computer to internet
i hope this helpful
thank you for using fixya
Feb 02, 2011 | Asrock P4i65GV Motherboard
My acer 4310 connects fast to wi-fi pero pag internet cable na as in ung dsl hindi gumagana
When you plugged in the ethernet cable, does it show on your windows tray (lower right corner of the screen) that the LAN is connected? It should show you "Connected" if you hover your mouse on the LAN icon.
Try also to plug in the ethernet cable to a different port on the router, and that the port number on the router is showing a solid green led light.
If all has been observed and still you cannot connect, look if the network adapter for your lan is working. RIGHT click your My Computer or "Computer" and select Manage. The Computer Management window will open. Click on the Device Manager on the left to show the list of devices on the right. Look for Network Adapters and click the + sign. See if your LAN adapter is not showing any yellow exclamation point. Also, right click on it and select Properties. You should see the device is working properly under status.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Acer Aspire 4315 Notebook
I found I needed a USB/Ethernet adaptor in order to connect my new broadband and purchased an ASIX AX88772A vai your product A31GY from Maplins. I'm having trouble in that the Broadband set up refuses to...
I allowed Windows Update to search for the right driver. This took a long time - I'd tried earlier but evidently hadn't let it run for long enough. It located and loaded a driver and everything was then fine: the ethernet connection (via adaptor) 'went live', my new broadband set-up software recognised it and proceeded sussessfully from there.
I assume that the device manager on my PC was correctly identifying corrupt drivers on the small CD supplied with the adaptor and that I'd managed to find uncorrupted ones on the internet via Windows Update.
Robin Lovelock
Dec 09, 2009 | Computers & Internet
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
Ethernet card losing connection
Try updating drivers. Go to device manager, then select your network card, then go to drivers tab and select update driver.
Jun 13, 2017 | Microsoft Ethernet MN-120 Network Adapter
I am unable to connect to the router using my ethernet cable. I am able to connect wirelessly. The other computers in my apartment can connect using ethernet or wireless. I did check driver/network adapter...
any chance the problem is with your cable?  if the device manager has the device listed and the driver is up to date (or even not showing problems)...
sorry for the obvious, but it has to be checked.  good luck.
Apr 19, 2009 | Computers & Internet
Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Oct 30, 2008 | Gigabyte GA-M59SLI-S5 Motherboard
I had to reinstall windows xp. Now I cannot connect to the internet.
Make sure the driver of the Ethernet Card on your computer is installed. You check it under Device Manager
Right-click My Computer > Properties > Hardware Tab > Device Manager > Network Adapters (click the +). If you see Other Devices with yellow exclamations like Ethernet Controller, that's it. You need to run the Motherboard CD to automatically install the ethernet driver.
Jul 24, 2008 | Computers & Internet
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
