Question about Gateway 4525GZ Notebook
Operating system & harddrive not found
I have a Gateway 4525 GZ notebook that I've had for about three years now.The computer has always run & worked excellent.Recently I got the blue screen then I ran the XP disc & repaired the problem.About a week later I went to turn on the computer & got operating system not found message now i put the XP disc in again to repair the problem again & windows setup can't find the harddrive now.I took out the old harddrive & installed another one and when I went to install XP on it I got the same message harddrive not found.I've taken apart the laptop & cleaned everything I could & then the dvd drive wasn't powering up. I removed the hard drive again & reinstalled it then the dvd drive worked again. I really don't know what's going here and any help would be greatly appreciated. Thanks for any help in advance.
  • 1 more comment
  • Nicholas bor Oct 26, 2008
    Yes I did & i still get the same message.When I'm in the bios menu the hard drive isn't there. It says primary master none secondary master my dvd drive. when I click on primary master it says type:auto & at the bottom where it says hdd firmware version there is nothing but dots & lines.
    I also get this message now realtek rtl8139 ethernet check controller cable.
    I was afraid it would come down to replacing the mother board because
    i tried almost everything I could think of. Thanks for your help.
  • Gateway Master
  • 5,568 Answers
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk? In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free Grisoft Home Page - Spybot S&D Spybot Home page - AdAware Lavasoft Home Page
Basic versions are either free or ask for donations.
Posted on Oct 26, 2008
  • Steve Allison
    Steve Allison Oct 26, 2008
    If the BIOS can't see your drive, there is a good chance the integrated drive controller has failed.
    Unfortunately, I doubt seriously that the controller is a replaceable IC but rather part of a chip set and that would mean a new or refurbished mother board and there is a chance that those two functions are under the control of the same chip or chipset.
    A good illustration of how different devices may be interrelated can be seen here:
    Northbridge/Southbridge definitions
My gateway 4525 battery is 95% charged but won't tune the computer
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 04, 2012 | Gateway 4525GZ Notebook
I have a Gateway GT5654 desktop that won't stop shutting down. I bought the computer brand new about 3 years ago, and I've never had any problems until now (I've even been running Norton 360...
it is possible that one of the three are going out on the computer, motherboard, harddrive, power supply, only a computer tech could tell which one.
Sep 21, 2011 | Gateway GT5654 Desktop PC
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
While trying to bootup my harddrive makes this clicking noise, and shows a message operating system not found, how do I correct this problem
Hi Mark,
The above message seems to hard drive issue. I recommend you to check with GWSCAN link. GWSCAN will isolate the issue with hard drive or not.
I believe above link will help to confirm your issue.
Sep 28, 2009 | Gateway M640XL-QS Notebook
Operating system not found
I would say either a bad harddrive or bad boot sector. If you are looking for a DIY solution, youll want to test the harddrive by running disk wizard or something similar or pulling the harddrive and putting it in a harddrive enclosure (available from The enclosure will hookup to another computer through usb or firewire and will allow you to backup your files if the harddrive is still good. If the harddrive isnt good, youll get errors while copying the files or it wont allow you to access the harddrive at all. Else, take it to a computer repairman to have them pull the harddrive and run tests on it.
Jun 10, 2009 | Sony VAIO Z1RA Notebook
Broken USB ports
Here's what I'd do:
Check your bios settings
Run a Live Linux cd lik Ubuntu or Knoppix
Update bios firmware
If you try all three and you get the same results then the problem is definitely hardware related.
If it was hardware related then I'd try removing all the pci cards hooked into the motherboard / clear cmos.
If it's software related then back up your files and reinstall the operating system.
Let me know if you need any additional details. I respond to my requests.
Best of luck!
May 11, 2009 | Gateway M320CS Notebook
17" gateway notebook oiwer source
I think returning it is your best option. It could be a bad motherboard. See if they have an expedited option.
Jun 14, 2008 | Gateway 19" Flat Panel LCD Monitor
Can the dvd combo drive of Gateway 6018 GZ be replaced??
There is a part number which you can use to order, so it can be replaced. Part #: 103336 This article describes how to replace the device. Replacing the optical drive is on page 3.
Sep 30, 2006 | Gateway 6018GZ RB6018GZ Notebook
Gateway 4525GZ Notebook Logo
223 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
