Question about Air Tools & Compressors
Central pneumatic model #67847 trips reset every 11 seconds, motor not hot
My Central Pneumatic 21 gal up ight air compressor will run for 11 seconds then trips the reset button. Motor is not getting hot. Is there an easy fix?
  • 41 Answers
SOURCE: central pneumatic 2 hp 4 gal air compressor has
can you please tell me where are the leak found as there are different place with dif temp seal
Posted on Sep 27, 2009
manhandy
  • 146 Answers
SOURCE: can't find air filter for central pneumatic air compressor
i do not know which one you taking about! the Air intake or in line moisture type on the discharge.
but both are universal just go to air compressor shop or go on line.
Posted on Jul 05, 2009
  • 3600 Answers
SOURCE: what type of oil for central pneumatic air
It should use 30 weight mineral oil, or 30 weight motor oil.
Posted on Aug 06, 2009
lindsay836
  • 677 Answers
SOURCE: I need parts for a central pneumatic compressor
http://www.harborfreight.com/manuals/93000-93999/93785.pdf
That should be it, please let me know.
Posted on Feb 06, 2010
  • 1383 Answers
SOURCE: I have a Central Pneumatic,
If air leaks when motor is off, fault most likely in-tank check valve. Follow discharge air line from pump to tank. Brass/steel valve at tank is the check valve. Remove hose to valve and check for leak. Replace as needed. If air is leaking while motor is running fault could be reed valves in head. Faulty reed valves in head, or torn head gaskets will cause very hot discharge air and tank will most likely never fill to shut off (or take a very long time to fill)
Posted on Sep 07, 2010
Have a 21 gal central pneumatic. 2.5 hp. With no pressure in tank, plugged into wall outlet. Upon start up it will run 20 seconds then the breaker on motor case trips. Barely used this thing.
the thermal circuit breaker is overloading
that can be from a faulty tcb or a problem in the compressor ( seized)
most need start/run capacitors for the motor to start and if it / they are faulty then that will blow the TCB
if it has 2 capacitors ( one for start which it is doing and the other for run then that capacitor may be the problem
if it has the one unit with 4 wires , replace the capacitor
suggest that get an electrician in to check out the unit
Sep 18, 2016 | Air Tools & Compressors
21 gal vertical Model 94667 will not fill tank.
Could be piston rings too. Have you looked here? http://www.centralpneumaticaircompressors.com/buying-central-pneumatic-air-compressor-parts/
Oct 14, 2013 | Air Tools & Compressors
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
I have a 21 gallon 4hp peak motor Central Pneumatic oil lubricated Model 47065 air compressor and it will not go to over 20 psi and it will just keep running
Possible that there is leak on the system or the piston/rings/cylinder has worn out.Also check for oil within the unit. Check the compression of the cycle and if this is too low it means that there is wear and tear and will require a overhauling and reset.
Mar 14, 2012 | Air Tools & Compressors
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Feb 14, 2012 | Air Tools & Compressors
I have a Central Pneumatic, 21 Gallon, 3HP air compressor. The compressor is exiting air through exthaust port.
Sep 06, 2010 | Air Tools & Compressors
How much oil for 2hp 8 gallon central pneumatic air #95386
i'm not sure of the solution but what type of oil did you use?
Apr 10, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
338 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
