Question about Sony Cyber-shot DSC-W70 Digital Camera
Screen only shows "access"
When I turn on the camera, the word "access" comes on the screen. By playing with the buttons, I can occasionally get an old picture on the screen, but then it tells me to turn the camera on and off.
    Novelist:
  • 198 Answers
For other users that may read this post, this problem is related with the lents mechanism. If the camera isn't able to properly initialise the CCD sensor or the lents servo-motors this error will occur. In anycase this will require qualified service intervention as it's not in anyway a user manageable problem.
Posted on Mar 03, 2007
One of my friends has the same problem with her camera, but we can't even get old pictures to come up on the screeen. When you turn it on it says access for about 15 seconds, then tells you to tell the camera off and then back on.
Posted on Oct 17, 2006
SOURCE:
Display screen no longer works while taking pictures
Sounds like they accidentally pressed the DISP or DISPLAY button on the back of the camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time with the camera turned on.
Aug 01, 2009 | Canon PowerShot A630 Digital Camera
PS3 won't even show the menu screen
I suggest trying to reset the system by turing the system off first. ( Do not cut the power switch off in the back of the system). Then hold the on button for 3 beeps. See what happens.
Mar 18, 2009 | Sony Playstation 3 (PS3) Console
Display will not come on
Turn your command dial to P or to auto. Press the menu button. The screen should light up with the main menu. If it does not, find the two buttons on your camera that has small green dots beside them. Press both of these buttons together at the same time until the LCD screen flashes on the top of the camera. Now try to access the menu again. If that does not help, call 1-800-nikonux for their 24/7/365 tech help
Dec 16, 2008 | Nikon D70s Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Access black screen problem
try this!
1.turn on the unit and switch it to play mode( by pressing the button next to th viewfinder.
2. press the menu button
3. select setup (the option with the toolbox icon)
4. inside setup look and select for setup 1(toolbox icon with a number 1 at the bottom)
5. then select initialize and select OK to every ptompt,
6. then it will pop up clock settings.
if this will not work then it would be better to hav the unit checkd and repaired by an authorized servicer. sony 1800-222-7669
Jan 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera wont stay on, please help
Possible that the Lens Mechanism is out of sync. If its still within warranty just bring it in and have it serviced. If not I may be able to help you out but it requires dismantling the camera,..
If any one knows a quicker and easier way maybe they can post it here But as far as experience goes thats what happened with mine,
Hope this helps
Oct 12, 2007 | Casio Exilim Card EX-S600 Digital Camera
Canon gl1 - no picture in the fold out lens
By placing the POWER switch into CAMERA mode, you will then be able to press the MENU button, and access all camera adjustments....including the LCD function.
Mar 05, 2007 | Canon GL1 Mini DV Digital Camcorder
Screen shows only 'Access'
You have probably dropped the camera. If you are brave enough to open the camera up you can put the rollers back on track. Not a difficult problem to solve.
Oct 17, 2006 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
