Question about KitchenAid KSRP22FNSS Side by Side Refrigerator
Water filter will not come out. broke end trying. now how to remove
If this is the base grille filter that normally comes out with a twist -- Jam a 10" long #3 phillips screwdriver down where the filter end is. Get it right into the end and tap it softly with a rubber mallet to get the phillips bit to "bite".
Now twist left 1/4 turn and pull.
Posted on Mar 01, 2009
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Broke the plastic screen that goes to the cold water inlet valve?
The broken bit of filter has probably got stuck under the rubber diaphragm in the inlet valve. You will have to strip the inlet valve and remove the piece. There should be 3 or 4 screws holding the valve together. Make a note of how it comes apart. There will be a spring, a metal plunger and the rubber diaphragm inside the valve.
Apr 27, 2017 | Maytag Washing Machines
Frigidaire water filter stuck
We had the same issue. My husband unscrewed the filter cover (1 screw on the left side of the filter under the light flap). Then he pushed the old filter in & lifted it up and it came right out.
Oct 02, 2012 | Frigidaire ULTRAWF Frigidaire PureSource...
I have replaced my ice maker filter. Now when the ice maker comes on or we press tab for water, the box where the filter cartridge pushes in leaks water through 2 holes in top of refrigerator side.
either the filter isn't in correctly or when you changed it out you broke the filter holder.take out the filter and try reinstalling it,also look at the filter to see if it's damaged or try putting the old filter back in,if it leaks with both filters then i'd have to say the filter holder is broke,if it only leaks with the new filter then you could have a defective filter.try reinstalling it.good luck.
Sep 05, 2011 | Refrigerators
I can't remove the filter sump from the Kenmore under sink filter unit. I am turning the correct direction. Broke one wrench already. Don't want to snap the second one. Full product id is: Kenmore Two...
Mark and unhook all the tubes from the filter. Take it out and place it on a table horizontally. This is all about correct leverage.
While holding the reverse osmosis system in one hand, slide the wrench into a canister and turn it counter-clockwise.
If this still does not work, you may have to soak the filter canisters (bottom housing part ONLY) in warm water with vinegar and try the steps above again.
How to change 10 RO Pre Filters
Nov 15, 2017 | Water Filters & Coolers
Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Nov 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Filter broke off in the holder
I have recently had to remove one that the end cap had broken off but I don't think you will be able to get this one out. You will need to replace the filter housing. It's not hard to do. You just need to get the part, pull the 2 screws holding it in along with the wire off to the left side, remove the water hoses and install the new housing.
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
When trying to remove my water filter from my whirlpool fridge, the screw end that fits into the fridge broke off. How can I get through the "tube" to remove that piece so I can put in a new...
Purchase a screw extractor the right size. It's like a reverse fluted drill bit. Use an appropriate extension and a reversable drill. Or.. find or cut a round piece of rubber in a cone shape of the right size to insert and grab the broken piece to spin it out CCW.
May 29, 2008 | Whirlpool Refrigerators
KitchenAid KSRP22FNSS Side by Side Refrigerator Logo
76 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
