Question about Apex Digital LD4088 LCD TV
Whats mounting bolt size for le40h88 - Apex Digital LD4088 LCD TV
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
What screw/bolt size is it to wall mount?
Contact the authorized dealer for more details about the sizes of hardware. Electro help
Oct 16, 2014 | Televison & Video
What size of bolts hold on the engine mounts
Take out one of the other mount bolts for a sample
You don't know how to measure bolt threads & convert
to metric if necessary?
That is a must if your going to work on any vehicle from
1980 on
Jan 22, 2013 | 1996 Dodge Caravan
What size bolts do i use to mount it
It is very likely that the correct mounting bolts to attach a wall mount to your TV are type M8 bolts 20 MM long. It is a rather standard size and you should be able to find them locally without a problem. This is the most probable size although you may find that it requires a different size. It should be either a M5 or M4 bolt of similar length. Give it a try, I think you will find it works perfectly!
Mar 07, 2011 | Toshiba 42HL67 42 in. LCD Television
What size are the mounting screws?
The brass mounting holes on the bottom of Hitachi data projectors require a 4mm bolt.
Typicall 4mm x 10 is the shortest bolt I will use if when installing a projector on a ceiling mount, and 4mm x 20 will be the longest. I also recommend picking up 3 washers and spacers of varying sizes if you want to insure the projector is mounted level without warping whatever it is you are attaching it to.
BMS makes great locking mounts that come with all the mounting hardware you'd need to attach a projector to it.
Jan 03, 2010 | Hitachi CP-S240 Multimedia Projector
Screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Dec 23, 2009 | Televison & Video
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
Looking for the correct size bolt for tranny mount.
Good work discovering the missing bolts. You didn't say if it's a manual or auto tranny,Check out the below site for a great diagram of the mounts and bolts, and the prices are good for OEM parts. Let me know if this doesn't help.
www.hondapartscheap.com/southbay/jsp/prddisplay.jsp?hidSwitch=&hidIrno=&catcgry1=CIVIC&catcgry2=1998&catcgry3=4DR+LX&catcgry4=KA5MT&catcgry5=MT++++++ENGINE+MOUNTS&vinsrch=no&ListAll=&prdrefno=&act=&count=0&quantity=0
Aug 10, 2009 | 1998 Honda Civic
Mounting TV
Assume you are mounting on the wall, if so a good mount will have the standard bolts in the package. If this is a used mount, you will need to determine the length based on the mount, the bolt size is either 1/4" or 5/16", probably the latter.
Dec 14, 2007 | Panasonic TH-50PX75U Plasma HDTV
What size bolts for mounting bracket??
I don't know the size but, I can bet it will be a metric bolt.
Apr 17, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Apex Digital LD4088 LCD TV Logo
97 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
