Question about Sharp Aquos Televison & Video
Ok, but my power supply is good ,but still very dead
So now where do i go,.i have heard it could be the main board, and do i check this out,.
  • 8 more comments
  • Carl Peters Feb 19, 2012
    the model lc37d43u, there is no light at alll not blinking or otherwise, nothing,. carl
    the voltage is missing from the input from the main board, and from what i checked all seem find on the power supply,.fuse ok, resisters good diodes good , line in good,.so what would be the most locical place to start to check voltage,.
    well ok i will try that, i usually have very little problemwith these sets so i know how this can throw you off,.
  • Sonny Berry
    Sonny Berry Feb 19, 2012
    Check wire socket P101 on the front Control board ( Where power led is) that plug shoul have +3.3V on both Pins 1 & 2 when using pin 3 as ground. If that supply is good check Diode D103 and Q102 both also on that same board
    thank you i will check,.
  • Carl Peters Feb 20, 2012
    i have tryed the voltage check where the led light is, nothing is thereand all diodes check out good,.,so what do you think , the main board is bad,.
    ok i will do that but as i remember there wasn't and voltage like that, and if it be the power supply where is the problem, everything seems fime,.
  • Carl Peters Feb 21, 2012
    well i did as you asked and there is no power there coming or going so i guess it is the main board, thanks you for your help, now i have to see where i can get a board cheap,.
    does anyone know where i can gety a diagram of the power board so i can repair it, thanks,.
  • Carl Peters Feb 25, 2012
    hi people i thank you all for your help, the problem was on the power board, a diod was the problem, thanks again,.
  • Sharp Master
  • 8,617 Answers
Need the actual model number from the set. Also does the power light come on or blink? If it blinks let me know how many times its blinking and I will assist with the issue.
Posted on Feb 19, 2012
  • 2 more comments
  • Sonny Berry
    It has to be the power supply board, or it could be the main but the main would be very unlikely. How have you verified that the power board is good? Was it replaced with a known good one? If so then it would have to be the main board causing the issue or the front keyboard. Remote control doesnt work but do the buttons on the set themselves have any effect??
  • Sonny Berry
    Sonny Berry Feb 20, 2012
    ok check wire plug P9702 for the +5V check it on the main board and also the power boards feed. If the voltage is on the power side and also the main side then the main board is bad. If not it has to be the power board.
  • Sonny Berry
    Sonny Berry Feb 21, 2012
    It would be the power board if there is no voltages on that plug from the power board going to the main.
  • Sonny Berry
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
  • 61 Answers
SOURCE: HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
Posted on May 15, 2008
Tech4lfe
  • 42 Answers
SOURCE: Westinghouse LTV-32w6 power light on, no video, no sound
One thing is to make sure the inverter board is unplugged when testing the voltages. A shorted inverter will shut down the power supply if the fuse dosen't blow first. There are fuses that don't look like fuses so they can be missed. The next thing would be to look for a connector from the main to power supply and see if there is a pin labeled power on or p.on or similar. The main board should turn this line high(5V) when you push the power button. If not you probably have a bad main board. Unless you can find good used boards they are both expensive. Around $200 for PS and $300 for main.
Posted on Jul 06, 2008
  • 41 Answers
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
Yeah if you don't have any power at all, no lights or anything its the power supply.
Posted on Oct 08, 2008
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
My acer aspire v5-531 will not turn on and no lights at all when connected to tested power supply
kindly remove the battery n check with power, if possible get checked the power connector of the power supply, with a multi meter, if its ok then its a main board issue. u have to change the main board
Jul 16, 2016 | Acer Aspire Laptop PC V5-531-4636
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
No power on Hatchi p42h401 allready replaced power supply
IF you got a good board and a lot of replacement boards aren't good the only other thing that would make the set dead is if you have a bad main board, if your able to pull the back off and test the either 3.5 or 5 volt standby voltage if its ok then look at the PSON voltage, it should be at a half volt and go to about 3.5 when the power button is pushed..if you don't have standby you have a bad power board yet, if you have standby but no PSON the main board is bad, if you have PSON its back to the PS as being bad...Good luck!!
Feb 01, 2018 | Hitachi P42H401 42 in. Plasma HDTV
Zenith z50pg10 its dead no click, no led blink nothing !
Zenith Flat panel TVs usually only have two boards in them Plasmas have a few more, doing a visual inspection of the power supply capacitors usually reveals swollen or bulging capacitors.
If the capacitors look good, voltage checks would be needed to isolate the problem to either the main board or power supply. Check for 5 volts to the IR board (& or keyboard) , if five volts is present suspect the main board
If this TV has voltages from power supply , suspect the Z, X and buffers
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
May 26, 2012 | Televison & Video
HP D7-1245DX Motherboard part number 506124-001 Power supply went bad, was running fine off of battery until battery went dead. Replaced power supply with good HP 463958-001 power supply, but it will...
I would first double-check the "known good" power supply. If there is something bad wrong with the MB, it could have blown the fuse in the power supply. I have seen very few fuses on motherboards, they are normally in the power supply. If the power supply checks out OK, then double check the connectors between the power supply and the MB.
Oct 02, 2017 | HEWLETT-PACKARD Hewlett Packard 506124-001...
Dead
Hello George, hi it seem your TV is on standby mode, this happens when the power supply board detects a short, overload or any part on both main and power supply board gone bad. This needs to be checked properly by a highly skilled tech people. The problem could be the main board or the power supply board. we usually check first the main board, for any bad parts, like loose screws/wiring, bulging capacitors, overheating ICs, or water marks. If a OK, we then check the power supply board, well usually this is the culprit, bulging capacitors, or overheating regulator. or you could replace the entire power supply board. check for its availability online or on your dealer, ask also for service if the charge is reasonable.
Apr 30, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have 140 LG 32LC7DC LCD TV's. 14 out of 140 failed. They would not power up. Have you heard of this problem with this model of LG?
Power Supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC7DC 32 in. LCD HDTV
Dead mother board
The problem with power surges, or low power (brownouts) causing excessive current draw can cause multiple problems to motherboards. Even if you were to pinpoint and repair one problem that appeared to fix the fault, several other components on the board may have been weakened, and prone to fail.
If you are certain that the power supply is 100% ok, then replace the MB.
The best power protection is to use a UPS.
Jan 05, 2008 | Intel Motherboard
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
63 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
