Question about Kenwood Car Audio & Video
How do u find the ground whire or install a kenwood kac 7205 I found the hot lead but cant find the ground and whats a p supply
Ground wire is black. if not able to find put one in yourself. red wire is power that comes on when you turn on the key, yellow is constant power for memory.
Posted on Feb 19, 2012
  • ijohnson22 Feb 19, 2012
    Ok found the constant power now cant find the power wire that comes out of the car that would go to the dec can I run one from the batt
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
Kenwood
run a constant hot (from a fused BATTERY lead) most folks will usually use a 0 or 2 gauge wire for "main" power and ground keep the ground as short as possible (it will hit much harder) and a normal I think 16 or 18 gauge for the "trigger" wire from the head (radio) hope this helps :)
May 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
My kac-910 keeps shuting off at high volumes after about ten minuets i have two 12s
loose ground? shortage? overheat? sounds to me personally that problem with subs or wire touching ground...so signaling for asmp to enter protect mode?
Jun 29, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac-5201 amp
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Sep 02, 2008 | Kenwood KAC-5201 Car Audio Amplifier
Kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Mar 13, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 21, 2008 | Kenwood KAC-X201T Car Audio Amplifier
Can't get my amp to turn on
You need to confirm that you have sufficient B+ and remote turn-on voltage.
Jan 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Amp won't turn on don't know if amp is fried
Very possible that you have a blown power supply in the amp. If you are running a mono amp then there is a very good chance that you have loaded your amp with too low of a speaker impedence and fried the power supply and maybe the output section of the audio area. Hope this helps.
Mar 30, 2007 | Kenwood KAC-8152D Car Audio Amplifier
Car Audio & Video Logo
386 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
