How to check error code H2 in Konica minolta copier 7115
After copying a single page the screen promted H2
Soulvisitor
  • 1113 Answers
SOURCE: konica minolta EP2010 error code c05
Fuser is hot section near paper exit, left side, replace fuser assem. to fix,
The fuser "melts toner into paper after printing", fuser runs hot at 180 deg, but yours isnt heating up, hence error, lamp blown, thermister faulty or thermal fuse, these are all parts of a fuser, odd occasions it is board that powers it, but thats rare.
Posted on Nov 08, 2007
  • 1003 Answers
SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
  • 175 Answers
SOURCE: H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Posted on Jun 23, 2009
jqsababa967
  • 145 Answers
SOURCE: C-D370 error code for Copier KONICA-MINOLTA C252
this has to do with what they call NAVRAM IS C
To troubleshoot the error:
1. Reset the code by pressing stop-0-7-1-3-9. This will display a "*" on the LCD. Press this button.
2. Perform a Data Clear and then perform the Setup Procedures from the beginning.
3. Perform a NVRAM Recovery Procedure. Please see attached document. To view the PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from RRUPTED/need to be reset BUT that will clear all the current setting especially if print to it.if you are willing to try ....
you should have a Tech do this...
good luck
Posted on Sep 20, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
I have a KONICA MINOLTA bizhub 7115, but I do not know the code developer (ATDC - auto adjust), please let me know. thank you
Has the developer been replaced? do not run this auto adjust unless that has been done. 36 mode will get to auto adjust.
Mar 03, 2015 | Konica Minolta Office Equipment & Supplies
How can i solve error code C0F32 in konica miniolta 7118
Press [Utility] -> [Stop] -> [0] -> [0] -> [Stop] -> [0] -> [1]. Go to [Adjustment] --> [ ATDC Adj. ] [Start], wait for 2 mins. it will automatically stop then turn Off / On copier. If C0F32 appear replaced the ATDC sensor located under the developing unit then calibrate again.
Oct 16, 2014 | Konica Minolta Konica 7115 7118 Compatible...
Wrench symbol on Konica 7115 means what?
PREVENTIVE MAINT. Replace drum, cleaning blade,developer etc. comes as a kit for the technicians to replace, clearing counter without doing things not good machine uses the counters to adjust voltage on certain parts and is the only way it knows new parts installed clear counter and not replace parts causes codes and image problems
Jun 25, 2012 | Minolta Office Equipment & Supplies
How to fix error c0f32 in konica minolta bizhub 180
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Mar 24, 2010 | Konica Minolta bizhub 180 All-In-One...
Error H2 after copying on Minolta Di151
Hello sir ; Here is the way to reset ,just opening and closing the lower front door.
Aug 18, 2009 | Konica Minolta Office Equipment & Supplies
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
146 people viewed this question
jasbo
jasbo
